[petsc-users] Question about MatCreateShell loca ros/colums
Wed Apr 14 19:54:49 CDT 2021
On Wed, Apr 14, 2021 at 5:56 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
> Dear PETSc dev team,
>    If I want PETSc to use my own parallel partition(instead of PETSc
> "evenly" partition rows), I assume I can provide local rows/columns as
> follows.
> MatCreateShell <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateShell.html#MatCreateShell>(MPI_Comm <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/MPI_Comm.html#MPI_Comm> comm,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> m,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> n,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> M,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> N,void *ctx,Mat <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat> *A)
>   If that's the case, what role does local columns play? Memory
> allocation? Should I use n (the global rows) or local rows or PETSC_DECIDE
> in this case?
The only role played by n is to match this matrix with parallel vectors
that you want it to act on. The local sizes should match. For square
matrices, this usually
means you match the local row size.
     Matt
> Thanks,
> Sam
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210414/f6907b62/attachment.html>
