[petsc-users] Question about MatCreateShell loca ros/colums
Sam Guo sam.guo at cd-adapco.com
Wed Apr 14 16:56:37 CDT 2021
Dear PETSc dev team,
   If I want PETSc to use my own parallel partition(instead of PETSc
"evenly" partition rows), I assume I can provide local rows/columns as
follows.
MatCreateShell <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateShell.html#MatCreateShell>(MPI_Comm
<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/MPI_Comm.html#MPI_Comm>
comm,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt>
n,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt>
M,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt>
N,void *ctx,Mat
<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat>
*A)
  If that's the case, what role does local columns play? Memory allocation?
Should I use n (the global rows) or local rows or PETSC_DECIDE in this case?
Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210414/bbe7a909/attachment.html>
