[petsc-users] Question about MatCreateShell loca ros/colums
Sam Guo sam.guo at cd-adapco.com
Wed Apr 14 20:12:41 CDT 2021
Thanks, Matt.
On Wed, Apr 14, 2021 at 5:55 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Apr 14, 2021 at 5:56 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>> Dear PETSc dev team,
>>    If I want PETSc to use my own parallel partition(instead of PETSc
>> "evenly" partition rows), I assume I can provide local rows/columns as
>> follows.
>> MatCreateShell <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatCreateShell.html#MatCreateShell>(MPI_Comm <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/MPI_Comm.html#MPI_Comm> comm,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> m,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> n,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> M,PetscInt <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscInt.html#PetscInt> N,void *ctx,Mat <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat> *A)
>>   If that's the case, what role does local columns play? Memory
>> allocation? Should I use n (the global rows) or local rows or PETSC_DECIDE
>> in this case?
> The only role played by n is to match this matrix with parallel vectors
> that you want it to act on. The local sizes should match. For square
> matrices, this usually
> means you match the local row size.
>   Thanks,
>      Matt
>> Thanks,
>> Sam
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210414/774004a3/attachment-0001.html>
