[petsc-users] PetscFV types
Fri Sep 18 05:24:06 CDT 2020
On Fri, Sep 18, 2020 at 4:01 AM Pierre Seize <Pierre.Seize at onera.fr> wrote:
> Hello,
> I do not understand what are the two available types for the PetscFV
> object : "upwind" and "leastsquares", because to me those two properties
> describe different parts of the Finite Volume formulation. Could someone
> explain, or give me some references ?
Sure. PetscFV is mostly an exercise for me to determine if the meshing and
data layout
infrastructure below can support finite volume methods, so the FV methods
that it does support
are rather rudimentary. My understanding of FV is quite limited. "upwind"
is just the naive, first
order FV method with pointwise Riemann solves for each local face. I called
it upwind since we
just update the state with the upwind data. I guess I could have called it
"gudonov" as well. The
"leastsquares" uses a least-squares reconstruction of the state over
cell+neighboring cells (closure
of the star of the faces) to try and achieve second-order where possible. I
this "reconstructed".
     Matt
> Thank you
> Pierre Seize
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200918/6c3bb63c/attachment.html>
