[petsc-users] PetscFV types
Pierre Seize
Pierre.Seize at onera.fr
Fri Sep 18 08:43:41 CDT 2020
So the difference between the two types is in DMPlexGetFaceFields : the
upwind just takes the cell averaged (or cell centerd) states, and the
least-squares use the gradient to reconstruct the states ?
Thanks
Pierre
On 18/09/20 12:24, Matthew Knepley wrote:
> On Fri, Sep 18, 2020 at 4:01 AM Pierre Seize <Pierre.Seize at onera.fr
> <mailto:Pierre.Seize at onera.fr>> wrote:
> Hello,
> I do not understand what are the two available types for the PetscFV
> object : "upwind" and "leastsquares", because to me those two
> properties
> describe different parts of the Finite Volume formulation. Could
> someone
> explain, or give me some references ?
> Sure. PetscFV is mostly an exercise for me to determine if the meshing
> and data layout
> infrastructure below can support finite volume methods, so the FV
> methods that it does support
> are rather rudimentary. My understanding of FV is quite limited.
> "upwind" is just the naive, first
> order FV method with pointwise Riemann solves for each local face. I
> called it upwind since we
> just update the state with the upwind data. I guess I could have
> called it "gudonov" as well. The
> "leastsquares" uses a least-squares reconstruction of the state over
> cell+neighboring cells (closure
> of the star of the faces) to try and achieve second-order where
> possible. I guess I could have called
> this "reconstructed".
> Thanks,
> Matt
> Thank you
> Pierre Seize
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/%7Eknepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200918/a12ae3cc/attachment.html>
