[petsc-users] How to activate the modified Gram-Schmidt orthogonalization process in Fortran?
Matthew Knepley
knepley at gmail.com
Fri Sep 11 15:06:53 CDT 2020
On Fri, Sep 11, 2020 at 3:56 PM Zhuo Chen <chenzhuotj at gmail.com> wrote:
> Hi Matthew,
> Yes, if use
> call KSPSetType(ksp,KSPGMRES,ierr);CHKERRQ(ierr)
> call KSPSetFromOptions(ksp,ierr);CHKERRQ(ierr)
> call
> PetscOptionsSetValue(PETSC_NULL_OPTIONS,'-ksp_gmres_modifiedgramschmidt','1',ierr);CHKERRQ(ierr)
> call
> PetscOptionsSetValue(PETSC_NULL_OPTIONS,'-ksp_view','',ierr);CHKERRQ(ierr)
Are you running in a loop?
Matt
> to see if the modified Gram-Schmidt process is actually active. The output
> is
> KSP Object: 4 MPI processes
> type: gmres
> restart=30, using Modified Gram-Schmidt Orthogonalization
> happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-11, absolute=1e-50, divergence=10000.
> left preconditioning
> using PRECONDITIONED norm type for convergence test
> I think that means calling PetscOptionsSetValue()
> after KSPSetFromOptions() works. Correct me if I am wrong.
> Best.
> On Fri, Sep 11, 2020 at 1:31 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Sep 11, 2020 at 3:05 PM Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>> Hi Hong,
>>> Thank you very much for the plan.
>>> Though it may be obvious to many Petsc gurus. I would like to summarize
>>> my solution to activate the modified Gram-Schmidt orthogonalization process
>>> in Fortran now. It may help some new Petsc users.
>>> Option 1: append the -ksp_gmres_modifiedgramschmidt at runtime, the code
>>> would look like
>>> and to run the program, use
>>> mpiexec -np 2 ./run -ksp_gmres_modifiedgramschmidt
>>> Option 2: use PetscOptionsSetValue()
>>> call
>> Does it work if you call SetValue() after SetFromOptions()? I would not
>> think that would work.
>> Thanks,
>> Matt
>>> mpiexec -np 2 ./run
>>> Best.
>>> On Fri, Sep 11, 2020 at 9:05 AM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
>>>> Zhuo,
>>>> I'll try to get it done after the incoming release. My hands are full
>>>> with more urgent tasks at moment. I'll let you know after I'm done.
>>>> Thanks for your patience.
>>>> Hong
>>>> *From:* Zhuo Chen <chenzhuotj at gmail.com>
>>>> *Sent:* Thursday, September 10, 2020 8:41 PM
>>>> *To:* Zhang, Hong <hzhang at mcs.anl.gov>
>>>> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>>>> *Subject:* Re: [petsc-users] How to activate the modified Gram-Schmidt
>>>> Hi Hong,
>>>> According to that very old thread, KSPGMRESSetOrthogonalization was not
>>>> implemented in Fortran. I did as you suggested and the compiler will tell
>>>> me
>>>> undefined reference to `kspgmressetorthogonalization_'
>>>> I think I will use the -ksp_gmres_modifiedgramschmidt method. Thank you
>>>> so much!
>>>> On Thu, Sep 10, 2020 at 7:32 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
>>>> Zhuo,
>>>> Call
>>>> KSPSetType(ksp,KSPGMRES);
>>>> KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization);
>>>> Hong
>>>> *Sent:* Thursday, September 10, 2020 8:17 PM
>>>> Hi Hong,
>>>> Thank you very much for your help.
>>>> It seems that if I simply append -ksp_gmres_modifiedgramschmidt the
>>>> warning goes away. However
>>>> KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization,ierr)
>>>> has another issue.
>>>> Error: Symbol ‘kspgmresmodifiedgramschmidtorthogonalization’ at (1) has
>>>> no IMPLICIT type
>>>> Is it because the argument is too long? I am using gcc 8.4.0 instead of
>>>> ifort
>>>> On Thu, Sep 10, 2020 at 7:08 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
>>>> Zhuo,
>>>> Run your code with option '-ksp_gmres_modifiedgramschmidt'. For
>>>> example,
>>>> petsc/src/ksp/ksp/tutorials
>>>> mpiexec -n 2 ./ex2 -ksp_view -ksp_gmres_modifiedgramschmidt
>>>> KSP Object: 2 MPI processes
>>>> type: gmres
>>>> tolerances: relative=0.000138889, absolute=1e-50, divergence=10000.
>>>> PC Object: 2 MPI processes
>>>> type: bjacobi
>>>> You can
>>>> call KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization)
>>>> in your program.
>>>> Hong
>>>> *From:* petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of
>>>> *Sent:* Thursday, September 10, 2020 7:52 PM
>>>> *To:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>>>> *Subject:* [petsc-users] How to activate the modified Gram-Schmidt
>>>> Dear Petsc users,
>>>> I found an ancient thread discussing this problem.
>>>> https://lists.mcs.anl.gov/pipermail/petsc-users/2011-October/010607.html
>>>> However, when I add
>>>> call
>>>> the program will tell me
>>>> WARNING! There are options you set that were not used!
>>>> WARNING! could be spelling mistake, etc!
>>>> There is one unused database option. It is:
>>>> Option left: name:-ksp_gmres_modifiedgramschmidt value: 1
>>>> I would like to know the most correct way to activate the modified
>>>> Gram-Schmidt orthogonalization process in Fortran. Thank you very much!
>>>> Best regards.
>>>> Zhuo Chen
>>>> Department of Physics
>>>> University of Alberta
>>>> Edmonton Alberta, Canada T6G 2E1
>>>> http://www.pas.rochester.edu/~zchen25/
>>>> Zhuo Chen
>>>> Zhuo Chen
>>> Zhuo Chen
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> Zhuo Chen
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200911/456056bd/attachment-0001.html>
