[petsc-users] How to activate the modified Gram-Schmidt orthogonalization process in Fortran?
Zhuo Chen chenzhuotj at gmail.com
Fri Sep 11 14:56:01 CDT 2020
Hi Matthew,
Yes, if use
call KSPSetType(ksp,KSPGMRES,ierr);CHKERRQ(ierr)
call KSPSetFromOptions(ksp,ierr);CHKERRQ(ierr)
call
PetscOptionsSetValue(PETSC_NULL_OPTIONS,'-ksp_gmres_modifiedgramschmidt','1',ierr);CHKERRQ(ierr)
call
PetscOptionsSetValue(PETSC_NULL_OPTIONS,'-ksp_view','',ierr);CHKERRQ(ierr)
to see if the modified Gram-Schmidt process is actually active. The output
is
KSP Object: 4 MPI processes
  type: gmres
    restart=30, using Modified Gram-Schmidt Orthogonalization
    happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-11, absolute=1e-50, divergence=10000.
  left preconditioning
  using PRECONDITIONED norm type for convergence test
I think that means calling PetscOptionsSetValue() after KSPSetFromOptions()
works. Correct me if I am wrong.
Best.
On Fri, Sep 11, 2020 at 1:31 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 11, 2020 at 3:05 PM Zhuo Chen <chenzhuotj at gmail.com> wrote:
>> Hi Hong,
>> Thank you very much for the plan.
>> Though it may be obvious to many Petsc gurus. I would like to summarize
>> my solution to activate the modified Gram-Schmidt orthogonalization process
>> in Fortran now. It may help some new Petsc users.
>> Option 1: append the -ksp_gmres_modifiedgramschmidt at runtime, the code
>> would look like
>> and to run the program, use
>> mpiexec -np 2 ./run -ksp_gmres_modifiedgramschmidt
>> Option 2: use PetscOptionsSetValue()
>> call
> Does it work if you call SetValue() after SetFromOptions()? I would not
> think that would work.
>   Thanks,
>      Matt
>> mpiexec -np 2 ./run
>> Best.
>> On Fri, Sep 11, 2020 at 9:05 AM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
>>> Zhuo,
>>> I'll try to get it done after the incoming release. My hands are full
>>> with more urgent tasks at moment. I'll let you know after I'm done.
>>> Thanks for your patience.
>>> Hong
>>> *From:* Zhuo Chen <chenzhuotj at gmail.com>
>>> *Sent:* Thursday, September 10, 2020 8:41 PM
>>> *To:* Zhang, Hong <hzhang at mcs.anl.gov>
>>> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>>> *Subject:* Re: [petsc-users] How to activate the modified Gram-Schmidt
>>> Hi Hong,
>>> According to that very old thread, KSPGMRESSetOrthogonalization was not
>>> implemented in Fortran. I did as you suggested and the compiler will tell
>>> me
>>> undefined reference to `kspgmressetorthogonalization_'
>>> I think I will use the -ksp_gmres_modifiedgramschmidt method. Thank you
>>> so much!
>>> On Thu, Sep 10, 2020 at 7:32 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
>>> Zhuo,
>>> Call
>>> KSPSetType(ksp,KSPGMRES);
>>> KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization);
>>> Hong
>>> *Sent:* Thursday, September 10, 2020 8:17 PM
>>> Hi Hong,
>>> Thank you very much for your help.
>>> It seems that if I simply append -ksp_gmres_modifiedgramschmidt the
>>> warning goes away. However
>>> KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization,ierr)
>>> has another issue.
>>> Error: Symbol ‘kspgmresmodifiedgramschmidtorthogonalization’ at (1) has
>>> no IMPLICIT type
>>> Is it because the argument is too long? I am using gcc 8.4.0 instead of
>>> ifort
>>> On Thu, Sep 10, 2020 at 7:08 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
>>> Zhuo,
>>> Run your code with option '-ksp_gmres_modifiedgramschmidt'. For example,
>>> petsc/src/ksp/ksp/tutorials
>>> mpiexec -n 2 ./ex2 -ksp_view -ksp_gmres_modifiedgramschmidt
>>> KSP Object: 2 MPI processes
>>>   type: gmres
>>>   tolerances:  relative=0.000138889, absolute=1e-50, divergence=10000.
>>> PC Object: 2 MPI processes
>>>   type: bjacobi
>>> You can
>>> call KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization)
>>> in your program.
>>> Hong
>>> *From:* petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Zhuo
>>> *Sent:* Thursday, September 10, 2020 7:52 PM
>>> *To:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>>> *Subject:* [petsc-users] How to activate the modified Gram-Schmidt
>>> Dear Petsc users,
>>> I found an ancient thread discussing this problem.
>>> https://lists.mcs.anl.gov/pipermail/petsc-users/2011-October/010607.html
>>> However, when I add
>>> call
>>> the program will tell me
>>> WARNING! There are options you set that were not used!
>>> WARNING! could be spelling mistake, etc!
>>> There is one unused database option. It is:
>>> Option left: name:-ksp_gmres_modifiedgramschmidt value: 1
>>> I would like to know the most correct way to activate the modified
>>> Gram-Schmidt orthogonalization process in Fortran. Thank you very much!
>>> Best regards.
>>> Zhuo Chen
>>> Department of Physics
>>> University of Alberta
>>> Edmonton Alberta, Canada T6G 2E1
>>> http://www.pas.rochester.edu/~zchen25/
>>> Zhuo Chen
>>> Zhuo Chen
>> Zhuo Chen
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
Zhuo Chen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200911/13ee5858/attachment-0001.html>
