[petsc-users] How to activate the modified Gram-Schmidt orthogonalization process in Fortran?
Zhuo Chen chenzhuotj at gmail.com
Fri Sep 11 15:10:30 CDT 2020
Hi Matthew,
Yes. These four lines are in a do while loop.
On Fri, Sep 11, 2020 at 2:07 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 11, 2020 at 3:56 PM Zhuo Chen <chenzhuotj at gmail.com> wrote:
>> Hi Matthew,
>> Yes, if use
>> call KSPSetType(ksp,KSPGMRES,ierr);CHKERRQ(ierr)
>> call KSPSetFromOptions(ksp,ierr);CHKERRQ(ierr)
>> call
>> PetscOptionsSetValue(PETSC_NULL_OPTIONS,'-ksp_gmres_modifiedgramschmidt','1',ierr);CHKERRQ(ierr)
>> call
>> PetscOptionsSetValue(PETSC_NULL_OPTIONS,'-ksp_view','',ierr);CHKERRQ(ierr)
> Are you running in a loop?
>   Thanks,
>      Matt
>> to see if the modified Gram-Schmidt process is actually active. The
>> output is
>> KSP Object: 4 MPI processes
>>   type: gmres
>>     restart=30, using Modified Gram-Schmidt Orthogonalization
>>     happy breakdown tolerance 1e-30
>>   maximum iterations=10000, initial guess is zero
>>   tolerances:  relative=1e-11, absolute=1e-50, divergence=10000.
>>   left preconditioning
>>   using PRECONDITIONED norm type for convergence test
>> I think that means calling PetscOptionsSetValue()
>> after KSPSetFromOptions() works. Correct me if I am wrong.
>> Best.
>> On Fri, Sep 11, 2020 at 1:31 PM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Sep 11, 2020 at 3:05 PM Zhuo Chen <chenzhuotj at gmail.com> wrote:
>>>> Hi Hong,
>>>> Thank you very much for the plan.
>>>> Though it may be obvious to many Petsc gurus. I would like to summarize
>>>> my solution to activate the modified Gram-Schmidt orthogonalization process
>>>> in Fortran now. It may help some new Petsc users.
>>>> Option 1: append the -ksp_gmres_modifiedgramschmidt at runtime, the
>>>> code would look like
>>>> and to run the program, use
>>>> mpiexec -np 2 ./run -ksp_gmres_modifiedgramschmidt
>>>> Option 2: use PetscOptionsSetValue()
>>>> call
>>> Does it work if you call SetValue() after SetFromOptions()? I would not
>>> think that would work.
>>>   Thanks,
>>>      Matt
>>>> mpiexec -np 2 ./run
>>>> Best.
>>>> On Fri, Sep 11, 2020 at 9:05 AM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
>>>>> Zhuo,
>>>>> I'll try to get it done after the incoming release. My hands are full
>>>>> with more urgent tasks at moment. I'll let you know after I'm done.
>>>>> Thanks for your patience.
>>>>> Hong
>>>>> *From:* Zhuo Chen <chenzhuotj at gmail.com>
>>>>> *Sent:* Thursday, September 10, 2020 8:41 PM
>>>>> *To:* Zhang, Hong <hzhang at mcs.anl.gov>
>>>>> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>>>>> *Subject:* Re: [petsc-users] How to activate the modified
>>>>> Hi Hong,
>>>>> According to that very old thread, KSPGMRESSetOrthogonalization was
>>>>> not implemented in Fortran. I did as you suggested and the compiler will
>>>>> tell me
>>>>> undefined reference to `kspgmressetorthogonalization_'
>>>>> I think I will use the -ksp_gmres_modifiedgramschmidt method. Thank
>>>>> you so much!
>>>>> On Thu, Sep 10, 2020 at 7:32 PM Zhang, Hong <hzhang at mcs.anl.gov>
>>>>> wrote:
>>>>> Zhuo,
>>>>> Call
>>>>> KSPSetType(ksp,KSPGMRES);
>>>>> KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization);
>>>>> Hong
>>>>> *Sent:* Thursday, September 10, 2020 8:17 PM
>>>>> Hi Hong,
>>>>> Thank you very much for your help.
>>>>> It seems that if I simply append -ksp_gmres_modifiedgramschmidt the
>>>>> warning goes away. However
>>>>> KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization,ierr)
>>>>> has another issue.
>>>>> Error: Symbol ‘kspgmresmodifiedgramschmidtorthogonalization’ at (1)
>>>>> has no IMPLICIT type
>>>>> Is it because the argument is too long? I am using gcc 8.4.0 instead
>>>>> of ifort
>>>>> On Thu, Sep 10, 2020 at 7:08 PM Zhang, Hong <hzhang at mcs.anl.gov>
>>>>> wrote:
>>>>> Zhuo,
>>>>> Run your code with option '-ksp_gmres_modifiedgramschmidt'. For
>>>>> example,
>>>>> petsc/src/ksp/ksp/tutorials
>>>>> mpiexec -n 2 ./ex2 -ksp_view -ksp_gmres_modifiedgramschmidt
>>>>> KSP Object: 2 MPI processes
>>>>>   type: gmres
>>>>>   tolerances:  relative=0.000138889, absolute=1e-50, divergence=10000.
>>>>> PC Object: 2 MPI processes
>>>>>   type: bjacobi
>>>>> You can
>>>>> call KSPGMRESSetOrthogonalization(ksp,KSPGMRESModifiedGramSchmidtOrthogonalization)
>>>>> in your program.
>>>>> Hong
>>>>> *From:* petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of
>>>>> *Sent:* Thursday, September 10, 2020 7:52 PM
>>>>> *To:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
>>>>> *Subject:* [petsc-users] How to activate the modified Gram-Schmidt
>>>>> Dear Petsc users,
>>>>> I found an ancient thread discussing this problem.
>>>>> https://lists.mcs.anl.gov/pipermail/petsc-users/2011-October/010607.html
>>>>> However, when I add
>>>>> call
>>>>> the program will tell me
>>>>> WARNING! There are options you set that were not used!
>>>>> WARNING! could be spelling mistake, etc!
>>>>> There is one unused database option. It is:
>>>>> Option left: name:-ksp_gmres_modifiedgramschmidt value: 1
>>>>> I would like to know the most correct way to activate the modified
>>>>> Gram-Schmidt orthogonalization process in Fortran. Thank you very much!
>>>>> Best regards.
>>>>> Zhuo Chen
>>>>> Department of Physics
>>>>> University of Alberta
>>>>> Edmonton Alberta, Canada T6G 2E1
>>>>> http://www.pas.rochester.edu/~zchen25/
>>>>> Zhuo Chen
>>>>> Zhuo Chen
>>>> Zhuo Chen
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> Zhuo Chen
> experiments lead.
> -- Norbert Wiener
Zhuo Chen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200911/ea83957d/attachment.html>
