[petsc-users] reset release branch
Barry Smith bsmith at petsc.dev
Thu Oct 1 10:06:45 CDT 2020
  Thibaut,
  master has not changed in any way, it's usage is the same as before the release. Only the maint branch has been renamed to release.
   Barry
> On Oct 1, 2020, at 3:30 AM, Appel, Thibaut <t.appel17 at imperial.ac.uk> wrote:
> Is ‘master’ still considered stable?
> Thibaut
>> Message: 1
>> Date: Wed, 30 Sep 2020 09:14:41 -0500 (CDT)
>> From: Satish Balay <balay at mcs.anl.gov>
>> To: petsc-dev at mcs.anl.gov
>> Cc: petsc-users at mcs.anl.gov
>> Subject: [petsc-users] reset release branch
>> Message-ID: <alpine.LFD.2.23.451.2009300902130.2949 at sb>
>> Content-Type: text/plain; charset=US-ASCII
>> All,
>> I had to force fix the release branch due to a bad merge.
>> If you've pulled on the release branch after the bad merge (before this fix) - and now have the commit 25cac2be9df307cc6f0df502d8399122c3a2b6a3 in it - i.e check with:
>> git branch --contains 25cac2be9df307cc6f0df502d8399122c3a2b6a3
>> please do:
>> git checkout master
>> git branch -D release
>> git fetch -p
>> git checkout release
>> [Note: As the petsc-3.14 release announcement e-mail indicated - we switched from using 'maint' branch to 'release' branch or release fixes]
>> Satish
