[petsc-users] Ainsworth formula to solve saddle point problems / preconditioner for shell matrices
Olivier Jamond
olivier.jamond at cea.fr
Thu Oct 1 12:31:23 CDT 2020
Dear all,
I am working on a finite-elements/finite-volumes code, whose distributed
solver is based on petsc. For FE, it relies on Lagrange multipliers for
the imposition of various boundary conditions or interactions (simple
dirichlet, contact, ...). This results in saddle point problems:
[S Ct][x]=[f]
[C 0 ][y] [g]
As discussed in this mailing list ("Saddle point problem with nested
matrix and a relatively small number of Lagrange multipliers"), the
fieldsplit/PC_COMPOSITE_SCHUR approach involves (2 + 'number of
iterations of the KSP for the Schur complement') KSPSolve(S, Sp). I
would like to try the formula given by Ainsworth in [1] to solve this
problem:
x = (Sp)^(-1) * fp
y = Rt * (f - S*x)
where:
Sp= Ct*C + Qt*S*Q
Q = I - P
P = R * C
R = Ct * (C*Ct)^(-1)
My input matrices (S and C) are MPIAIJ matrices. I create a shell matrix
for Sp (because it involves (C*Ct)^(-1) so I think it may be a bad idea
to compute it explicitly...) with the MatMult operator to use it in a
KSPSolve. The C matrix and g vector are scaled so that the condition
number of Sp is similar to the one of S.
It works, but my main problem is that because Sp is a shell matrix, as
far as I understand, I deprive myself of all the petsc
preconditioners... I tried to use S as a preconditioning matrix, but
it's not good: With a GAMG preconditioner, my iteration number is about
4 times higher than in a "debug" version where I compute Sp explicitly
as a MPIAIJ matrix and use it as preconditioning matrix.
Is there a way to use the petsc preconditioners for shell matrices or at
least to define a shell preconditioner that internally calls the petsc
preconditioners?
In the end I would like to have something like GAMG(Ct*C + Qt*S*Q) as a
preconditioner (here Q is a shell matrix), or something
like Qt*GAMG(S)*Q (which from matlab experimentation could be a
good preconditioner).
Many thanks,
Olivier
[1]: Ainsworth, M. (2001). Essential boundary conditions and multi-point
constraints in finite element analysis. Computer Methods in Applied
Mechanics and Engineering, 190(48), 6323-6339.
