[petsc-users] Possible bug PETSc+Complex+CUDA
Junchao Zhang
junchao.zhang at gmail.com
Fri May 29 09:02:58 CDT 2020
Hi, Jorge,
I knew this problem and a fix is coming. Thanks.
--Junchao Zhang
On Fri, May 29, 2020 at 7:52 AM Jorge Chiva Segura <
jorge.chiva.segura at gmail.com> wrote:
> Dear all,
> I just wanted to add what we found in case that it can help to solve this
> problem:
> * Examples ex2.c, ex11.c and ex32.c under src/ksp/ksp/tutorials all of
> them seg-fault with "-mat_type mpiaijcusparse" or "-vec_type mpicuda" with
> CUDA 9.2 and 10.2.
> Examples ex2.c and ex32.c work fine if PETSc scalar type is set to real
> instead of complex. PETSc has been compiled with gcc-6.4.0
> * Here:
> https://dynamite.readthedocs.io/en/latest/tips.html#gpu-support
> it is mentioned that there is some problem for CUDA versions 8 and
> above.
> * It seems that the same problem was mentioned in this thread:
> https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2019-February/037748.html
> Please, let me know if you need any extra information.
> Thank you very much for your help.
> Best regards,
> Jorge
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200529/7a6a3fa8/attachment.html>
