[petsc-users] Possible bug PETSc+Complex+CUDA
Jorge Chiva Segura jorge.chiva.segura at gmail.com
Fri May 29 07:51:14 CDT 2020
Dear all,
I just wanted to add what we found in case that it can help to solve this
problem:
* Examples ex2.c, ex11.c and ex32.c under src/ksp/ksp/tutorials all of them
seg-fault with "-mat_type mpiaijcusparse" or "-vec_type mpicuda" with CUDA
9.2 and 10.2.
   Examples ex2.c and ex32.c work fine if PETSc scalar type is set to real
instead of complex. PETSc has been compiled with gcc-6.4.0
* Here:
  https://dynamite.readthedocs.io/en/latest/tips.html#gpu-support
  it is mentioned that there is some problem for CUDA versions 8 and above.
* It seems that the same problem was mentioned in this thread:
https://lists.mcs.anl.gov/mailman/htdig/petsc-users/2019-February/037748.html
Please, let me know if you need any extra information.
Thank you very much for your help.
Best regards,
Jorge
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200529/acfd0efb/attachment.html>
