[petsc-users] Possible bug PETSc+Complex+CUDA
    Rui Silva
    rui.silva at uam.es
    Thu May 21 10:37:42 CDT 2020
Hi Matt,
I am using CUDA 9.2. I will try to compile with CUDA 10.2.
Best regards,
Rui
Às 17:21 de 21/05/2020, Matthew Knepley escreveu:
> On Thu, May 21, 2020 at 10:53 AM Rui Silva <rui.silva at uam.es
> <mailto:rui.silva at uam.es>> wrote:
>     Hello everyone,
>     I am trying to run PETSc (with complex numbers in the GPU). When I
>     call
>     the VecWAXPY routine using the complex version of PETSc and mpicuda
>     vectors, the program fails with a segmentation fault. This problem
>     does
>     not appear, if I run the complex version with mpi vectors or with the
>     real version using mpicuda vectors. Is there any problem using
>     CUDA+complex PETSc?
>     Furthermore, I use the -log_view option to run the complex+gpu code,
>     otherwise the program fails at the beggining.
> What version of CUDA do you have? There are bugs in the versions
> before 10.2.
>   Thanks,
>     Matt
>     Best regards,
>     Rui Silva
>       Dr. Rui Emanuel Ferreira da Silva
>       Departamento de Física Teórica de la Materia Condensada
>       Universidad Autónoma de Madrid, Spain
>     https://ruiefdasilva.wixsite.com/ruiefdasilva
>     https://mmuscles.eu/
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200521/773b8096/attachment-0001.html>
