[petsc-users] Possible bug PETSc+Complex+CUDA
Thu May 21 11:02:56 CDT 2020
On Thu, May 21, 2020 at 11:31 AM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> Oh, there is also an issue I have recently noticed and did not have yet
> the time to fix it
> With complex numbers, we use the definitions for complexes from thrust and
> this does not seem to be always compatible to whatever the C compiler uses
> Matt, take a look at petscsytypes.h and you will see the issue
> https://gitlab.com/petsc/petsc/-/blob/master/include/petscsystypes.h#L208
> For sure, you need to configure petsc with --with-clanguage=cxx, but even
> that does not to seem make it work on a CUDA box I have recently tried out
> (CUDA 10.1)
> I believe the issue arise even if you call VecSet(v,0) on a VECCUDA
So Karl and Junchao say that with 10.2 it is working. Do you have access to
10.2?
     Matt
> On May 21, 2020, at 6:21 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, May 21, 2020 at 10:53 AM Rui Silva <rui.silva at uam.es> wrote:
>> Hello everyone,
>> I am trying to run PETSc (with complex numbers in the GPU). When I call
>> the VecWAXPY routine using the complex version of PETSc and mpicuda
>> vectors, the program fails with a segmentation fault. This problem does
>> not appear, if I run the complex version with mpi vectors or with the
>> real version using mpicuda vectors. Is there any problem using
>> CUDA+complex PETSc?
>> Furthermore, I use the -log_view option to run the complex+gpu code,
>> otherwise the program fails at the beggining.
> What version of CUDA do you have? There are bugs in the versions before
> 10.2.
>   Thanks,
>     Matt
>> Best regards,
>> Rui Silva
>>   Dr. Rui Emanuel Ferreira da Silva
>>   Departamento de Física Teórica de la Materia Condensada
>>   Universidad Autónoma de Madrid, Spain
>>   https://ruiefdasilva.wixsite.com/ruiefdasilva
>>   https://mmuscles.eu/
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200521/09660085/attachment.html>
