[petsc-users] Possible bug PETSc+Complex+CUDA
Junchao Zhang junchao.zhang at gmail.com
Thu May 21 11:15:20 CDT 2020
I tested this example with cuda 10.2, it did segfault. I'm looking into it.
--Junchao Zhang
On Thu, May 21, 2020 at 11:04 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, May 21, 2020 at 11:31 AM Stefano Zampini <
> stefano.zampini at gmail.com> wrote:
>> Oh, there is also an issue I have recently noticed and did not have yet
>> the time to fix it
>> With complex numbers, we use the definitions for complexes from thrust
>> and this does not seem to be always compatible to whatever the C compiler
>> uses
>> Matt, take a look at petscsytypes.h and you will see the issue
>> https://gitlab.com/petsc/petsc/-/blob/master/include/petscsystypes.h#L208
>> For sure, you need to configure petsc with --with-clanguage=cxx, but even
>> that does not to seem make it work on a CUDA box I have recently tried out
>> (CUDA 10.1)
>> I believe the issue arise even if you call VecSet(v,0) on a VECCUDA
> So Karl and Junchao say that with 10.2 it is working. Do you have access
> to 10.2?
>   Thanks,
>      Matt
>> On May 21, 2020, at 6:21 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, May 21, 2020 at 10:53 AM Rui Silva <rui.silva at uam.es> wrote:
>>> Hello everyone,
>>> I am trying to run PETSc (with complex numbers in the GPU). When I call
>>> the VecWAXPY routine using the complex version of PETSc and mpicuda
>>> vectors, the program fails with a segmentation fault. This problem does
>>> not appear, if I run the complex version with mpi vectors or with the
>>> real version using mpicuda vectors. Is there any problem using
>>> CUDA+complex PETSc?
>>> Furthermore, I use the -log_view option to run the complex+gpu code,
>>> otherwise the program fails at the beggining.
>> What version of CUDA do you have? There are bugs in the versions before
>> 10.2.
>>   Thanks,
>>     Matt
>>> Best regards,
>>> Rui Silva
>>>   Dr. Rui Emanuel Ferreira da Silva
>>>   Departamento de Física Teórica de la Materia Condensada
>>>   Universidad Autónoma de Madrid, Spain
>>>   https://ruiefdasilva.wixsite.com/ruiefdasilva
>>>   https://mmuscles.eu/
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200521/32f65a3f/attachment.html>
