[petsc-users] Possible bug PETSc+Complex+CUDA
Matthew Knepley
knepley at gmail.com
Thu May 21 10:21:55 CDT 2020
On Thu, May 21, 2020 at 10:53 AM Rui Silva <rui.silva at uam.es> wrote:
> Hello everyone,
> I am trying to run PETSc (with complex numbers in the GPU). When I call
> the VecWAXPY routine using the complex version of PETSc and mpicuda
> vectors, the program fails with a segmentation fault. This problem does
> not appear, if I run the complex version with mpi vectors or with the
> real version using mpicuda vectors. Is there any problem using
> CUDA+complex PETSc?
> Furthermore, I use the -log_view option to run the complex+gpu code,
> otherwise the program fails at the beggining.
What version of CUDA do you have? There are bugs in the versions before
10.2.
Matt
> Best regards,
> Rui Silva
> Dr. Rui Emanuel Ferreira da Silva
> Departamento de Física Teórica de la Materia Condensada
> Universidad Autónoma de Madrid, Spain
> https://ruiefdasilva.wixsite.com/ruiefdasilva
> https://mmuscles.eu/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200521/08b45a3c/attachment.html>
