[petsc-users] Possible bug PETSc+Complex+CUDA
Rui Silva
rui.silva at uam.es
Thu May 21 09:53:17 CDT 2020
Hello everyone,
I am trying to run PETSc (with complex numbers in the GPU). When I call
the VecWAXPY routine using the complex version of PETSc and mpicuda
vectors, the program fails with a segmentation fault. This problem does
not appear, if I run the complex version with mpi vectors or with the
real version using mpicuda vectors. Is there any problem using
CUDA+complex PETSc?
Furthermore, I use the -log_view option to run the complex+gpu code,
otherwise the program fails at the beggining.
Best regards,
Rui Silva
Dr. Rui Emanuel Ferreira da Silva
Departamento de Física Teórica de la Materia Condensada
Universidad Autónoma de Madrid, Spain
https://ruiefdasilva.wixsite.com/ruiefdasilva
https://mmuscles.eu/
all : odesolve.exe
clean ::
rm -f *.o odesolve.exe
include ${SLEPC_DIR}/lib/slepc/conf/slepc_common
# FC_FLAGS := $(filter-out -Wall,${FC_FLAGS}) -ffree-line-length-none
%.exe: %.o
-${FLINKER} -o $@ $< ${SLEPC_LIB}
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200521/5b407fb5/attachment.bin>
