[petsc-users] TS generating inconsistent data
Zhang, Hong
hongzhang at anl.gov
Tue Mar 17 16:09:36 CDT 2020
Zane,
Stefano’s suggestion should have fixed your code. I just want to let you know that it is not a requirement to call TSResetTrajectory() and there are other ways to fix your problem.
Based on my experience, you might have called TSSaveTrajectory() in an unnecessary place, for example,
TSSaveTrajectory()
TSSolve() /* generate a reference solution or for some other purpose */
{ /* optimization loop */
TSSolve() /* forward run for sensitivity calculation */
TSAdjointSolve() /* backward run for sensitivity calculation */
Here, the first call to TSSolve() actually does not need the trajectory data. You can easily fix the ‘inconsistent data’ error by doing
TSSaveTrajectory()
Alternatively, you can use the command line option -ts_trajectory_use_history 0 (you need to call TSSetFromOptions() after TSSaveTrajectory() to receive the TSTrajectory options).
Hong (Mr.)
On Mar 14, 2020, at 10:54 AM, Zane Charles Jakobs <Zane.Jakobs at colorado.edu<mailto:Zane.Jakobs at colorado.edu>> wrote:
Hi PETSc devs,
I have some code that implements (essentially) 4D-VAR with PETSc, and the results of both my forward and adjoint integrations look correct to me (i.e. calling TSSolve() and then TSAdjointSolve() works correctly as far as I can tell). However, when I try to use a TaoSolve() to optimize my initial condition, I get this error message:
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: History id should be unique
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.12.4-783-g88ddbcab12 GIT Date: 2020-02-21 16:53:25 -0600
[0]PETSC ERROR: ./var_ic_test on a arch-linux2-c-debug named DiffeoInvariant by diffeoinvariant Sat Mar 14 09:39:05 2020
[0]PETSC ERROR: Configure options CFLAGS="-O3 -march=native -mtune=native -fPIE" --with-shared-libraries=1 --with-openmp=1 --with-threads=1 --with-fortran=0 --with-avx2=1 CXXOPTFLAGS="-O3 -march=native -mtune=native -fPIE" --with-cc=clang --with-cxx=clang++ --download-mpich
[0]PETSC ERROR: #1 TSHistoryUpdate() line 82 in /usr/local/petsc/src/ts/interface/tshistory.c
[0]PETSC ERROR: #2 TSTrajectorySet() line 73 in /usr/local/petsc/src/ts/trajectory/interface/traj.c
[0]PETSC ERROR: #3 TSSolve() line 4005 in /usr/local/petsc/src/ts/interface/ts.c
[0]PETSC ERROR: #4 MixedModelFormVARICFunctionGradient() line 301 in mixed.c
[0]PETSC ERROR: #5 TaoComputeObjectiveAndGradient() line 261 in /usr/local/petsc/src/tao/interface/taosolver_fg.c
[0]PETSC ERROR: #6 TaoSolve_LMVM() line 23 in /usr/local/petsc/src/tao/unconstrained/impls/lmvm/lmvm.c
[0]PETSC ERROR: #7 TaoSolve() line 219 in /usr/local/petsc/src/tao/interface/taosolver.c
[0]PETSC ERROR: #8 MixedModelOptimize() line 639 in mixed.c
[0]PETSC ERROR: #9 MixedModelOptimizeInitialCondition() line 648 in mixed.c
[0]PETSC ERROR: #10 main() line 76 in var_ic_test.c
[0]PETSC ERROR: No PETSc Option Table entries
[0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov<mailto:petsc-maint at mcs.anl.gov>----------
In the function MixedModelFormVARICFunctionGradient(), I do
ierr = TSSetTime(model->ts, 0.0);CHKERRQ(ierr);
ierr = TSSetStepNumber(model->ts, 0);CHKERRQ(ierr);
ierr = TSSetFromOptions(model->ts);CHKERRQ(ierr);
ierr = TSSetMaxTime(model->ts, model->obs->t);CHKERRQ(ierr);
ierr = TSSolve(model->ts, model->X);CHKERRQ(ierr);
... [allocating and setting cost gradient vec]
ierr = TSSetCostGradients(model->ts, 1, model->lambda, NULL);CHKERRQ(ierr);
ierr = TSAdjointSolve(model->ts);CHKERRQ(ierr);
ierr = VecCopy(model->lambda[0], G);CHKERRQ(ierr);
What might be causing the above error? Am I using a deprecated version of the Tao interface? (I'm using TaoSetObjectiveAndGradientRoutine, as done in ex20_opt_ic.c)
Thanks!
-Zane Jakobs
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200317/60c49bcf/attachment.html>
