[petsc-users] TS generating inconsistent data
Zhang, Hong
hongzhang at anl.gov
Sat Mar 14 13:50:22 CDT 2020
What happens if you add -ts_trajectory_use_history 0 to your command line options?
Hong
On Mar 14, 2020, at 10:54 AM, Zane Charles Jakobs <Zane.Jakobs at colorado.edu<mailto:Zane.Jakobs at colorado.edu>> wrote:
Hi PETSc devs,
I have some code that implements (essentially) 4D-VAR with PETSc, and the results of both my forward and adjoint integrations look correct to me (i.e. calling TSSolve() and then TSAdjointSolve() works correctly as far as I can tell). However, when I try to use a TaoSolve() to optimize my initial condition, I get this error message:
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: History id should be unique
[0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.12.4-783-g88ddbcab12 GIT Date: 2020-02-21 16:53:25 -0600
[0]PETSC ERROR: ./var_ic_test on a arch-linux2-c-debug named DiffeoInvariant by diffeoinvariant Sat Mar 14 09:39:05 2020
[0]PETSC ERROR: Configure options CFLAGS="-O3 -march=native -mtune=native -fPIE" --with-shared-libraries=1 --with-openmp=1 --with-threads=1 --with-fortran=0 --with-avx2=1 CXXOPTFLAGS="-O3 -march=native -mtune=native -fPIE" --with-cc=clang --with-cxx=clang++ --download-mpich
[0]PETSC ERROR: #1 TSHistoryUpdate() line 82 in /usr/local/petsc/src/ts/interface/tshistory.c
[0]PETSC ERROR: #2 TSTrajectorySet() line 73 in /usr/local/petsc/src/ts/trajectory/interface/traj.c
[0]PETSC ERROR: #3 TSSolve() line 4005 in /usr/local/petsc/src/ts/interface/ts.c
[0]PETSC ERROR: #4 MixedModelFormVARICFunctionGradient() line 301 in mixed.c
[0]PETSC ERROR: #5 TaoComputeObjectiveAndGradient() line 261 in /usr/local/petsc/src/tao/interface/taosolver_fg.c
[0]PETSC ERROR: #6 TaoSolve_LMVM() line 23 in /usr/local/petsc/src/tao/unconstrained/impls/lmvm/lmvm.c
[0]PETSC ERROR: #7 TaoSolve() line 219 in /usr/local/petsc/src/tao/interface/taosolver.c
[0]PETSC ERROR: #8 MixedModelOptimize() line 639 in mixed.c
[0]PETSC ERROR: #9 MixedModelOptimizeInitialCondition() line 648 in mixed.c
[0]PETSC ERROR: #10 main() line 76 in var_ic_test.c
[0]PETSC ERROR: No PETSc Option Table entries
[0]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov<mailto:petsc-maint at mcs.anl.gov>----------
In the function MixedModelFormVARICFunctionGradient(), I do
ierr = TSSetTime(model->ts, 0.0);CHKERRQ(ierr);
ierr = TSSetStepNumber(model->ts, 0);CHKERRQ(ierr);
ierr = TSSetFromOptions(model->ts);CHKERRQ(ierr);
ierr = TSSetMaxTime(model->ts, model->obs->t);CHKERRQ(ierr);
ierr = TSSolve(model->ts, model->X);CHKERRQ(ierr);
... [allocating and setting cost gradient vec]
ierr = TSSetCostGradients(model->ts, 1, model->lambda, NULL);CHKERRQ(ierr);
ierr = TSAdjointSolve(model->ts);CHKERRQ(ierr);
ierr = VecCopy(model->lambda[0], G);CHKERRQ(ierr);
What might be causing the above error? Am I using a deprecated version of the Tao interface? (I'm using TaoSetObjectiveAndGradientRoutine, as done in ex20_opt_ic.c)
Thanks!
-Zane Jakobs
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200314/d9fc67f3/attachment.html>
