[petsc-users] Problems with MKL?
Adolfo Rodriguez
adantra at gmail.com
Thu Mar 5 11:23:59 CST 2020
Satish,
Thanks you for super-fast reply. Unfortunately, I cannot follow your
suggestion because the application I am linking PETSc is being compiled
with INTEL and gcc will not work, same goes with mpich. However, I am
positively sure that the problem is that the original application links to
mkl STATICALLY, while petsc links to the dynamic libraries. Also, I would
like to compile PETSC statically.
My question is: can I link to the statical mkl libraries? I tried
--with-blas-lapcak-lib=mkl_xx.a and did not work (I am doing exactly that
in windows and works).
Thanks for your help,
Adolfo
On Thu, Mar 5, 2020 at 10:25 AM Satish Balay <balay at mcs.anl.gov> wrote:
> You can try running the code in a debugger and check on the values before
> the blas call.
> Or make a debug build with gcc/gfortran/--download-fblaslapack
> --download-mpich and try valgrind again.
> BTW: I don't see MKL in configure options here - so likely system
> blas/lapack is used..
> Satish
> On Thu, 5 Mar 2020, Adolfo Rodriguez wrote:
> > I am experiencing a very stubborn issue, apparently related to an MKL
> > issue. I am solving a linear system using ksp which works well on
> windows.
> > I am trying to port this program to Linux now but I have been getting an
> > error coming from the solver (the matrix, right-hand side, and initial
> > solution vectors have been constructed without any issues). However, when
> > trying to compute the norm of any vector I get and error. Running the
> same
> > program with the debug option on, I get the message shown below. I tried
> > valgrind but did not help. Any suggestions?
> > Regards,
> > Adolfo
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> > probably memory access out of range
> > [0]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> > [0]PETSC ERROR: or see
> > https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac
> OS X
> > to find memory corruption errors
> > [0]PETSC ERROR: likely location of problem given in stack below
> > [0]PETSC ERROR: --------------------- Stack Frames
> > [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> > [0]PETSC ERROR: INSTEAD the line number of the start of the
> function
> > [0]PETSC ERROR: is given.
> > [0]PETSC ERROR: [0] BLASasum line 259
> > /home/rodriad/CODE/petsc-3.12.3/src/vec/vec/impls/seq/bvec2.c
> > [0]PETSC ERROR: [0] VecNorm_Seq line 221
> > [0]PETSC ERROR: [0] VecNorm line 213
> > /home/rodriad/CODE/petsc-3.12.3/src/vec/vec/interface/rvector.c
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Signal received
> > [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
> for
> > trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.12.3, Jan, 03, 2020
> > [0]PETSC ERROR: Unknown Name on a arch-linux-oxy-dbg named ohylrss0 by
> > rodriad Thu Mar 5 10:08:03 2020
> > [0]PETSC ERROR: Configure options --with-debugging=yes
> --with-mpi-dir=/apps/Intel/XEcluster/compilers_and_libraries_2018.0.128/linux/mpi/intel64
> > COPTFLAGS=-debug CXXOPTFLAGS=-debug FOPTFLAGS=-debug
> > PETSC_ARCH=arch-linux-oxy-dbg
> > [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
> > application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200305/a03d505d/attachment.html>
