[petsc-users] Problems with MKL?
Satish Balay
balay at mcs.anl.gov
Thu Mar 5 10:25:15 CST 2020
You can try running the code in a debugger and check on the values before the blas call.
Or make a debug build with gcc/gfortran/--download-fblaslapack --download-mpich and try valgrind again.
BTW: I don't see MKL in configure options here - so likely system blas/lapack is used..
Satish
On Thu, 5 Mar 2020, Adolfo Rodriguez wrote:
> I am experiencing a very stubborn issue, apparently related to an MKL
> issue. I am solving a linear system using ksp which works well on windows.
> I am trying to port this program to Linux now but I have been getting an
> error coming from the solver (the matrix, right-hand side, and initial
> solution vectors have been constructed without any issues). However, when
> trying to compute the norm of any vector I get and error. Running the same
> program with the debug option on, I get the message shown below. I tried
> valgrind but did not help. Any suggestions?
> Regards,
> Adolfo
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see
> https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X
> to find memory corruption errors
> [0]PETSC ERROR: likely location of problem given in stack below
> [0]PETSC ERROR: --------------------- Stack Frames
> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [0]PETSC ERROR: INSTEAD the line number of the start of the function
> [0]PETSC ERROR: is given.
> [0]PETSC ERROR: [0] BLASasum line 259
> /home/rodriad/CODE/petsc-3.12.3/src/vec/vec/impls/seq/bvec2.c
> [0]PETSC ERROR: [0] VecNorm_Seq line 221
> [0]PETSC ERROR: [0] VecNorm line 213
> /home/rodriad/CODE/petsc-3.12.3/src/vec/vec/interface/rvector.c
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for
> trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.12.3, Jan, 03, 2020
> [0]PETSC ERROR: Unknown Name on a arch-linux-oxy-dbg named ohylrss0 by
> rodriad Thu Mar 5 10:08:03 2020
> [0]PETSC ERROR: Configure options --with-debugging=yes
> --with-mpi-dir=/apps/Intel/XEcluster/compilers_and_libraries_2018.0.128/linux/mpi/intel64
> COPTFLAGS=-debug CXXOPTFLAGS=-debug FOPTFLAGS=-debug
> PETSC_ARCH=arch-linux-oxy-dbg
> [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
