[petsc-users] Inertia computation fails
Perceval Desforges
perceval.desforges at polytechnique.edu
Thu Mar 5 08:00:45 CST 2020
Ah thank you, I suspected I made a mistake, I hadn't received a copy of
my email...
What is the reason for this failure? Is there anything I can do about
it?
Perceval,
> The address here should be petsc-users - not petsc-users-bounces
> balay at sb /home/balay/git-repo/slepc (master=)
> $ git grep 'Inertia computation fails'
> src/eps/impls/krylov/krylovschur/ks-slice.c: if (zeros) SETERRQ1(((PetscObject)eps)->comm,PETSC_ERR_CONV_FAILED,"Inertia computation fails in %g",sr->int1);
> src/eps/impls/krylov/krylovschur/ks-slice.c: if (zeros) SETERRQ1(((PetscObject)eps)->comm,PETSC_ERR_CONV_FAILED,"Inertia computation fails in %g",newShift);
> src/pep/impls/krylov/stoar/qslice.c: if (!nconv) SETERRQ1(((PetscObject)pep)->comm,PETSC_ERR_CONV_FAILED,"Inertia computation fails in %g",nzshift);
> src/pep/impls/krylov/stoar/qslice.c: if (zeros) SETERRQ1(((PetscObject)pep)->comm,PETSC_ERR_CONV_FAILED,"Inertia computation fails in %g",newShift);
> So the message is likely coming from slepc
> Satish
> ---------- Forwarded message ----------
> Date: Thu, 05 Mar 2020 14:43:13 +0100
> From: Perceval Desforges <perceval.desforges at polytechnique.edu>
> To: petsc-users <petsc-users-bounces at mcs.anl.gov>
> Subject: Inertia computation fails
> Dear PETSc developpers, I am using SLEPC and MUMPS to calculate the eigenvalues of a real
> symmetric matrix in an interval. I have come upon a crash and I was
> unable to find any documentation on the error I got.
> The error is: Inertia computation fails in 2.19893 Is this a slepc, a Petsc or a mumps problem?
> Thanks,
> Perceval
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200305/3b8d4368/attachment.html>
