[petsc-users] Inertia computation fails
Jose E. Roman
jroman at dsic.upv.es
Tue Mar 10 10:49:21 CDT 2020
I need to know the exact code you are using to configure the solver and the command line you use to run the code.
Jose
> El 10 mar 2020, a las 16:31, Perceval Desforges <perceval.desforges at polytechnique.edu> escribió:
> Hello again,
> I've tried following your recommendations, and yet the computation still fails with the same error message even when i take a very large interval (the failed value is at 1.91 and the interval goes from 1.5 to 3).
> Could anything else be causing this?
> Thanks again.
> Best regards,
> Perceval,
>> Sorry I hadn't seen that you had responded. Thanks a lot, I'll try that.
>> Regards,
>> Perceval,
>> Are you using the EPSKrylovSchurSetDetectZeros() option? As in this example https://slepc.upv.es/documentation/current/src/eps/examples/tutorials/ex25.c.html
>> If so, then the explanation is probably that one of the endpoints of your interval coincides with an eigenvalue. Try with a slightly different interval.
>> Jose
>> El 5 mar 2020, a las 14:51, Satish Balay via petsc-users <petsc-users at mcs.anl.gov> escribió:
>> The address here should be petsc-users - not petsc-users-bounces
>> balay at sb /home/balay/git-repo/slepc (master=)
>> $ git grep 'Inertia computation fails'
>> src/eps/impls/krylov/krylovschur/ks-slice.c: if (zeros) SETERRQ1(((PetscObject)eps)->comm,PETSC_ERR_CONV_FAILED,"Inertia computation fails in %g",sr->int1);
>> src/eps/impls/krylov/krylovschur/ks-slice.c: if (zeros) SETERRQ1(((PetscObject)eps)->comm,PETSC_ERR_CONV_FAILED,"Inertia computation fails in %g",newShift);
>> src/pep/impls/krylov/stoar/qslice.c: if (!nconv) SETERRQ1(((PetscObject)pep)->comm,PETSC_ERR_CONV_FAILED,"Inertia computation fails in %g",nzshift);
>> src/pep/impls/krylov/stoar/qslice.c: if (zeros) SETERRQ1(((PetscObject)pep)->comm,PETSC_ERR_CONV_FAILED,"Inertia computation fails in %g",newShift);
>> So the message is likely coming from slepc
>> Satish
>> ---------- Forwarded message ----------
>> Date: Thu, 05 Mar 2020 14:43:13 +0100
>> From: Perceval Desforges <perceval.desforges at polytechnique.edu>
>> To: petsc-users <petsc-users-bounces at mcs.anl.gov>
>> Subject: Inertia computation fails
>> Dear PETSc developpers, I am using SLEPC and MUMPS to calculate the eigenvalues of a real
>> symmetric matrix in an interval. I have come upon a crash and I was
>> unable to find any documentation on the error I got. The error is: Inertia computation fails in 2.19893 Is this a slepc, a Petsc or a mumps problem? Thanks, Perceval
