[petsc-users] PETSc initialization error
Barry Smith bsmith at petsc.dev
Fri Jun 26 15:28:25 CDT 2020
  Ah, so you get the crash the second time you call PetscInitialize()?  That is a problem because we do intend to support that capability (but you much call PetscFinalize() each time also).
  Barry
> On Jun 26, 2020, at 3:25 PM, Sam Guo <sam.guo at cd-adapco.com> wrote:
> Hi Barry,
>    Thanks for the quick response.
>    I will call PetscInitialize once and skip the PetscFinalize for now to avoid the crash. The crash is actually in PetscInitialize, not PetscFinalize.
> Thanks,
> Sam
> On Fri, Jun 26, 2020 at 1:21 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>   Sam,
>   You can skip PetscFinalize() so long as you only call PetscInitialize() once. It is not desirable in general to skip the finalize because PETSc can't free all its data structures and you cannot see the PETSc logging information with -log_view but in terms of the code running correctly you do not need to call PetscFinalize.
>    If your code crashes in PetscFinalize() please send the full error output and we can try to help you debug it.
>    Barry
>> On Jun 26, 2020, at 3:14 PM, Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
>> To clarify, we have a mpi wrapper (so we can switch to different mpi at runtime). I compile petsc using our mpi wrapper.
>> If I just call PETSc initialize once without calling finallize, it is ok. My question to you is that: can I skip finalize?
>> Our program calls mpi_finalize at end anyway.
>> On Fri, Jun 26, 2020 at 1:09 PM Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
>> Hi Junchao,
>>    Attached please find the configure.log.
>>    I also attach the pinit.c which contains your patch (I am currently using 3.11.3. I've applied your patch to 3.11.3). Your patch fixes the serial version. The error now is about the parallel.
>>    Here is the error log:
>> [1]PETSC ERROR: #1 PetscInitialize() line 969 in ../../../petsc/src/sys/objects/pinit.c
>> [1]PETSC ERROR: #2 checkError() line 56 in ../../../physics/src/eigensolver/SLEPc.cpp
>> [1]PETSC ERROR: #3 PetscInitialize() line 966 in ../../../petsc/src/sys/objects/pinit.c
>> [1]PETSC ERROR: #4 SlepcInitialize() line 262 in ../../../slepc/src/sys/slepcinit.c
>> [0]PETSC ERROR: #1 PetscInitialize() line 969 in ../../../petsc/src/sys/objects/pinit.c
>> [0]PETSC ERROR: #2 checkError() line 56 in ../../../physics/src/eigensolver/SLEPc.cpp
>> [0]PETSC ERROR: #3 PetscInitialize() line 966 in ../../../petsc/src/sys/objects/pinit.c
>> [0]PETSC ERROR: #4 SlepcInitialize() line 262 in ../../../slepc/src/sys/slepcinit.c
>> PETSC ERROR: Logging has not been enabled.
>> You might have forgotten to call PetscInitialize().
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> with errorcode 56.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> Thanks,
>> Sam
>> On Thu, Jun 25, 2020 at 7:37 PM Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>> Sam,
>>    The MPI_Comm_create_keyval() error was fixed in maint/master. From the error message, it seems you need to configure --with-log=1
>>    Otherwise, please send your full error stack trace and configure.log.
>>   Thanks.
>> --Junchao Zhang
>> On Thu, Jun 25, 2020 at 2:18 PM Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
>> Hi Junchao,
>>    I now encountered the same error with parallel. I am wondering if there is a need for parallel fix as well.
>> On Sat, Jun 20, 2020 at 7:35 PM Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
>> Hi Junchao,
>>    Your patch works.
>> Thanks,
>> Sam
>> On Sat, Jun 20, 2020 at 4:23 PM Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>> On Sat, Jun 20, 2020 at 12:24 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>    Junchao,
>>      This is a good bug fix. It solves the problem when PETSc initialize is called many times.
>>      There is another fix you can do to limit PETSc mpiuni running out of attributes inside a single PETSc run:
>> int MPI_Comm_create_keyval(MPI_Copy_function *copy_fn,MPI_Delete_function *delete_fn,int *keyval,void *extra_state)
>>  if (num_attr >= MAX_ATTR){
>>    for (i=0; i<num_attr; i++) {
>>      if (!attr_keyval[i].extra_state) {
>> attr_keyval[i].extra_state is provided by user (could be NULL). We can not rely on it.
>>         /* reuse this slot */
>>         attr_keyval[i].extra_state = extra_state;
>>        attr_keyval[i.]del         = delete_fn;
>>        *keyval = i;
>>         return MPI_SUCCESS;
>>   return MPIUni_Abort(MPI_COMM_WORLD,1);
>>   attr_keyval[num_attr].extra_state = extra_state;
>>   attr_keyval[num_attr].del         = delete_fn;
>>   *keyval                           = num_attr++;
>>   return MPI_SUCCESS;
>>   This will work if the user creates tons of attributes but is constantly deleting some as they new ones. So long as the number outstanding at one time is < MAX_ATTR)
>> Barry
>>> On Jun 20, 2020, at 10:54 AM, Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>>> I don't understand what your session means. Let's try this patch
>>> diff --git a/src/sys/mpiuni/mpi.c b/src/sys/mpiuni/mpi.c
>>> index d559a513..c058265d 100644
>>> --- a/src/sys/mpiuni/mpi.c
>>> +++ b/src/sys/mpiuni/mpi.c
>>> @@ -283,6 +283,7 @@ int MPI_Finalize(void)
>>>    MPI_Comm_free(&comm);
>>>    comm = MPI_COMM_SELF;
>>> +  num_attr = 1; /* reset the counter */
>>>    MPI_was_finalized = 1;
>>>    return MPI_SUCCESS;
>>> --Junchao Zhang
>>> On Sat, Jun 20, 2020 at 10:48 AM Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
>>> Typo: I mean “Assuming initializer is only needed once for entire session”
>>> On Saturday, June 20, 2020, Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
>>> Assuming finalizer is only needed once for entire session(?), I can put initializer into the static block to call it once but where do I call finalizer?
>>> On Saturday, June 20, 2020, Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>>> The counter num_attr should be recycled. But first try to call PETSc initialize/Finalize only once to see it fixes the error.
>>> --Junchao Zhang
>>> On Sat, Jun 20, 2020 at 12:48 AM Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
>>> To clarify, I call PETSc initialize and PETSc finalize everytime I call SLEPc:
>>>   PetscInitializeNoPointers(argc,args,nullptr,nullptr);
>>>   SlepcInitialize(&argc,&args,static_cast<char*>(nullptr),help);
>>>   //calling slepc
>>>   SlepcFinalize();
>>>    PetscFinalize();
>>> On Fri, Jun 19, 2020 at 10:32 PM Sam Guo <sam.guo at cd-adapco.com <mailto:sam.guo at cd-adapco.com>> wrote:
>>> Dear PETSc team,
>>>    When I called SLEPc multiple time, I eventually got following error:
>>> MPI operation not supported by PETSc's sequential MPI wrappers
>>> [0]PETSC ERROR: #1 PetscInitialize() line 967 in ../../../petsc/src/sys/objects/pinit.c
>>> [0]PETSC ERROR: #2 SlepcInitialize() line 262 in ../../../slepc/src/sys/slepcinit.c
>>> [0]PETSC ERROR: #3 SlepcInitializeNoPointers() line 359 in ../../../slepc/src/sys/slepcinit.c
>>>   I debugged: it is because of following in petsc/src/sys/mpiuni/mpi.c
>>> in function int MPI_Comm_create_keyval(MPI_Copy_function *copy_fn,MPI_Delete_function *delete_fn,int *keyval,void *extra_state)
>>> num_attr is declared static and keeps increasing every time MPI_Comm_create_keyval is called.
>>> I am using petsc 3.11.3 but found 3.13.2 has the same logic.
>>> Is this a bug or I didn't use it correctly?
>>> Thanks,
>>> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200626/32ba61ac/attachment-0001.html>
