[petsc-users] PETSc initialization error
Sam Guo
sam.guo at cd-adapco.com
Fri Jun 26 15:33:14 CDT 2020
I get the crash after calling Initialize/Finalize multiple times. Junchao
fixed the bug for serial but parallel still crashes.
On Fri, Jun 26, 2020 at 1:28 PM Barry Smith <bsmith at petsc.dev> wrote:
> Ah, so you get the crash the second time you call PetscInitialize()?
> That is a problem because we do intend to support that capability (but you
> much call PetscFinalize() each time also).
> Barry
> On Jun 26, 2020, at 3:25 PM, Sam Guo <sam.guo at cd-adapco.com> wrote:
> Hi Barry,
> Thanks for the quick response.
> I will call PetscInitialize once and skip the PetscFinalize for now to
> avoid the crash. The crash is actually in PetscInitialize, not
> PetscFinalize.
> Thanks,
> Sam
> On Fri, Jun 26, 2020 at 1:21 PM Barry Smith <bsmith at petsc.dev> wrote:
>> Sam,
>> You can skip PetscFinalize() so long as you only call PetscInitialize()
>> once. It is not desirable in general to skip the finalize because PETSc
>> can't free all its data structures and you cannot see the PETSc logging
>> information with -log_view but in terms of the code running correctly you
>> do not need to call PetscFinalize.
>> If your code crashes in PetscFinalize() please send the full error
>> output and we can try to help you debug it.
>> Barry
>> On Jun 26, 2020, at 3:14 PM, Sam Guo <sam.guo at cd-adapco.com> wrote:
>> To clarify, we have a mpi wrapper (so we can switch to different mpi at
>> runtime). I compile petsc using our mpi wrapper.
>> If I just call PETSc initialize once without calling finallize, it is ok.
>> My question to you is that: can I skip finalize?
>> Our program calls mpi_finalize at end anyway.
>> On Fri, Jun 26, 2020 at 1:09 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>> Hi Junchao,
>>> Attached please find the configure.log.
>>> I also attach the pinit.c which contains your patch (I am currently
>>> using 3.11.3. I've applied your patch to 3.11.3). Your patch fixes the
>>> serial version. The error now is about the parallel.
>>> Here is the error log:
>>> [1]PETSC ERROR: #1 PetscInitialize() line 969 in
>>> ../../../petsc/src/sys/objects/pinit.c
>>> [1]PETSC ERROR: #2 checkError() line 56 in
>>> ../../../physics/src/eigensolver/SLEPc.cpp
>>> [1]PETSC ERROR: #3 PetscInitialize() line 966 in
>>> [1]PETSC ERROR: #4 SlepcInitialize() line 262 in
>>> ../../../slepc/src/sys/slepcinit.c
>>> [0]PETSC ERROR: #1 PetscInitialize() line 969 in
>>> [0]PETSC ERROR: #2 checkError() line 56 in
>>> [0]PETSC ERROR: #3 PetscInitialize() line 966 in
>>> [0]PETSC ERROR: #4 SlepcInitialize() line 262 in
>>> PETSC ERROR: Logging has not been enabled.
>>> You might have forgotten to call PetscInitialize().
>>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>> with errorcode 56.
>>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>>> You may or may not see output from other processes, depending on
>>> exactly when Open MPI kills them.
>>> Thanks,
>>> Sam
>>> On Thu, Jun 25, 2020 at 7:37 PM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> Sam,
>>>> The MPI_Comm_create_keyval() error was fixed in maint/master. From
>>>> the error message, it seems you need to configure --with-log=1
>>>> Otherwise, please send your full error stack trace and configure.log.
>>>> Thanks.
>>>> --Junchao Zhang
>>>> On Thu, Jun 25, 2020 at 2:18 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>> Hi Junchao,
>>>>> I now encountered the same error with parallel. I am wondering if
>>>>> there is a need for parallel fix as well.
>>>>> On Sat, Jun 20, 2020 at 7:35 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>>> Hi Junchao,
>>>>>> Your patch works.
>>>>>> Thanks,
>>>>>> Sam
>>>>>> On Sat, Jun 20, 2020 at 4:23 PM Junchao Zhang <
>>>>>> junchao.zhang at gmail.com> wrote:
>>>>>>> On Sat, Jun 20, 2020 at 12:24 PM Barry Smith <bsmith at petsc.dev>
>>>>>>> wrote:
>>>>>>>> Junchao,
>>>>>>>> This is a good bug fix. It solves the problem when PETSc
>>>>>>>> initialize is called many times.
>>>>>>>> There is another fix you can do to limit PETSc mpiuni running
>>>>>>>> out of attributes inside a single PETSc run:
>>>>>>>> int MPI_Comm_create_keyval(MPI_Copy_function
>>>>>>>> *copy_fn,MPI_Delete_function *delete_fn,int *keyval,void *extra_state)
>>>>>>>> if (num_attr >= MAX_ATTR){
>>>>>>>> for (i=0; i<num_attr; i++) {
>>>>>>>> if (!attr_keyval[i].extra_state) {
>>>>>>> attr_keyval[i].extra_state is provided by user (could be NULL). We
>>>>>>> can not rely on it.
>>>>>>>> /* reuse this slot */
>>>>>>>> attr_keyval[i].extra_state = extra_state;
>>>>>>>> attr_keyval[i.]del = delete_fn;
>>>>>>>> *keyval = i;
>>>>>>>> return MPI_SUCCESS;
>>>>>>>> return MPIUni_Abort(MPI_COMM_WORLD,1);
>>>>>>>> attr_keyval[num_attr].extra_state = extra_state;
>>>>>>>> attr_keyval[num_attr].del = delete_fn;
>>>>>>>> *keyval = num_attr++;
>>>>>>>> return MPI_SUCCESS;
>>>>>>>> This will work if the user creates tons of attributes but is
>>>>>>>> constantly deleting some as they new ones. So long as the number
>>>>>>>> outstanding at one time is < MAX_ATTR)
>>>>>>>> Barry
>>>>>>>> On Jun 20, 2020, at 10:54 AM, Junchao Zhang <
>>>>>>>> I don't understand what your session means. Let's try this patch
>>>>>>>> diff --git a/src/sys/mpiuni/mpi.c b/src/sys/mpiuni/mpi.c
>>>>>>>> index d559a513..c058265d 100644
>>>>>>>> --- a/src/sys/mpiuni/mpi.c
>>>>>>>> +++ b/src/sys/mpiuni/mpi.c
>>>>>>>> @@ -283,6 +283,7 @@ int MPI_Finalize(void)
>>>>>>>> MPI_Comm_free(&comm);
>>>>>>>> comm = MPI_COMM_SELF;
>>>>>>>> + num_attr = 1; /* reset the counter */
>>>>>>>> MPI_was_finalized = 1;
>>>>>>>> return MPI_SUCCESS;
>>>>>>>> --Junchao Zhang
>>>>>>>> On Sat, Jun 20, 2020 at 10:48 AM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>>> wrote:
>>>>>>>>> Typo: I mean “Assuming initializer is only needed once for entire
>>>>>>>>> session”
>>>>>>>>> On Saturday, June 20, 2020, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>>>>>>> Assuming finalizer is only needed once for entire session(?), I
>>>>>>>>>> can put initializer into the static block to call it once but where do I
>>>>>>>>>> call finalizer?
>>>>>>>>>> On Saturday, June 20, 2020, Junchao Zhang <
>>>>>>>>>>> The counter num_attr should be recycled. But first try to call
>>>>>>>>>>> PETSc initialize/Finalize only once to see it fixes the error.
>>>>>>>>>>> --Junchao Zhang
>>>>>>>>>>> On Sat, Jun 20, 2020 at 12:48 AM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> To clarify, I call PETSc initialize and PETSc finalize
>>>>>>>>>>>> everytime I call SLEPc:
>>>>>>>>>>>> PetscInitializeNoPointers(argc,args,nullptr,nullptr);
>>>>>>>>>>>> SlepcInitialize(&argc,&args,static_cast<char*>(nullptr),help);
>>>>>>>>>>>> //calling slepc
>>>>>>>>>>>> SlepcFinalize();
>>>>>>>>>>>> PetscFinalize();
>>>>>>>>>>>> On Fri, Jun 19, 2020 at 10:32 PM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>>>>>>> wrote:
>>>>>>>>>>>>> Dear PETSc team,
>>>>>>>>>>>>> When I called SLEPc multiple time, I eventually got
>>>>>>>>>>>>> following error:
>>>>>>>>>>>>> MPI operation not supported by PETSc's sequential MPI wrappers
>>>>>>>>>>>>> [0]PETSC ERROR: #1 PetscInitialize() line 967 in
>>>>>>>>>>>>> [0]PETSC ERROR: #2 SlepcInitialize() line 262 in
>>>>>>>>>>>>> [0]PETSC ERROR: #3 SlepcInitializeNoPointers() line 359 in
>>>>>>>>>>>>> I debugged: it is because of following in
>>>>>>>>>>>>> petsc/src/sys/mpiuni/mpi.c
>>>>>>>>>>>>> in function int MPI_Comm_create_keyval(MPI_Copy_function
>>>>>>>>>>>>> num_attr is declared static and keeps increasing every
>>>>>>>>>>>>> time MPI_Comm_create_keyval is called.
>>>>>>>>>>>>> I am using petsc 3.11.3 but found 3.13.2 has the same logic.
>>>>>>>>>>>>> Is this a bug or I didn't use it correctly?
>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200626/3ab7d0a6/attachment.html>
