[petsc-users] PETSc initialization error
Sam Guo
sam.guo at cd-adapco.com
Fri Jun 26 15:25:12 CDT 2020
Hi Barry,
Thanks for the quick response.
I will call PetscInitialize once and skip the PetscFinalize for now to
avoid the crash. The crash is actually in PetscInitialize, not
PetscFinalize.
Sam
On Fri, Jun 26, 2020 at 1:21 PM Barry Smith <bsmith at petsc.dev> wrote:
> Sam,
> You can skip PetscFinalize() so long as you only call PetscInitialize()
> once. It is not desirable in general to skip the finalize because PETSc
> can't free all its data structures and you cannot see the PETSc logging
> information with -log_view but in terms of the code running correctly you
> do not need to call PetscFinalize.
> If your code crashes in PetscFinalize() please send the full error
> output and we can try to help you debug it.
> Barry
> On Jun 26, 2020, at 3:14 PM, Sam Guo <sam.guo at cd-adapco.com> wrote:
> To clarify, we have a mpi wrapper (so we can switch to different mpi at
> runtime). I compile petsc using our mpi wrapper.
> If I just call PETSc initialize once without calling finallize, it is ok.
> My question to you is that: can I skip finalize?
> Our program calls mpi_finalize at end anyway.
> On Fri, Jun 26, 2020 at 1:09 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>> Hi Junchao,
>> Attached please find the configure.log.
>> I also attach the pinit.c which contains your patch (I am currently
>> using 3.11.3. I've applied your patch to 3.11.3). Your patch fixes the
>> serial version. The error now is about the parallel.
>> Here is the error log:
>> [1]PETSC ERROR: #1 PetscInitialize() line 969 in
>> ../../../petsc/src/sys/objects/pinit.c
>> [1]PETSC ERROR: #2 checkError() line 56 in
>> ../../../physics/src/eigensolver/SLEPc.cpp
>> [1]PETSC ERROR: #3 PetscInitialize() line 966 in
>> [1]PETSC ERROR: #4 SlepcInitialize() line 262 in
>> ../../../slepc/src/sys/slepcinit.c
>> [0]PETSC ERROR: #1 PetscInitialize() line 969 in
>> [0]PETSC ERROR: #2 checkError() line 56 in
>> [0]PETSC ERROR: #3 PetscInitialize() line 966 in
>> [0]PETSC ERROR: #4 SlepcInitialize() line 262 in
>> PETSC ERROR: Logging has not been enabled.
>> You might have forgotten to call PetscInitialize().
>> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>> with errorcode 56.
>> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> You may or may not see output from other processes, depending on
>> exactly when Open MPI kills them.
>> Thanks,
>> Sam
>> On Thu, Jun 25, 2020 at 7:37 PM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> Sam,
>>> The MPI_Comm_create_keyval() error was fixed in maint/master. From
>>> the error message, it seems you need to configure --with-log=1
>>> Otherwise, please send your full error stack trace and configure.log.
>>> Thanks.
>>> --Junchao Zhang
>>> On Thu, Jun 25, 2020 at 2:18 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>> Hi Junchao,
>>>> I now encountered the same error with parallel. I am wondering if
>>>> there is a need for parallel fix as well.
>>>> On Sat, Jun 20, 2020 at 7:35 PM Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>> Hi Junchao,
>>>>> Your patch works.
>>>>> Thanks,
>>>>> Sam
>>>>> On Sat, Jun 20, 2020 at 4:23 PM Junchao Zhang <junchao.zhang at gmail.com>
>>>>> wrote:
>>>>>> On Sat, Jun 20, 2020 at 12:24 PM Barry Smith <bsmith at petsc.dev>
>>>>>> wrote:
>>>>>>> Junchao,
>>>>>>> This is a good bug fix. It solves the problem when PETSc
>>>>>>> initialize is called many times.
>>>>>>> There is another fix you can do to limit PETSc mpiuni running
>>>>>>> out of attributes inside a single PETSc run:
>>>>>>> int MPI_Comm_create_keyval(MPI_Copy_function
>>>>>>> *copy_fn,MPI_Delete_function *delete_fn,int *keyval,void *extra_state)
>>>>>>> if (num_attr >= MAX_ATTR){
>>>>>>> for (i=0; i<num_attr; i++) {
>>>>>>> if (!attr_keyval[i].extra_state) {
>>>>>> attr_keyval[i].extra_state is provided by user (could be NULL). We
>>>>>> can not rely on it.
>>>>>>> /* reuse this slot */
>>>>>>> attr_keyval[i].extra_state = extra_state;
>>>>>>> attr_keyval[i.]del = delete_fn;
>>>>>>> *keyval = i;
>>>>>>> return MPI_SUCCESS;
>>>>>>> return MPIUni_Abort(MPI_COMM_WORLD,1);
>>>>>>> attr_keyval[num_attr].extra_state = extra_state;
>>>>>>> attr_keyval[num_attr].del = delete_fn;
>>>>>>> *keyval = num_attr++;
>>>>>>> return MPI_SUCCESS;
>>>>>>> This will work if the user creates tons of attributes but is
>>>>>>> constantly deleting some as they new ones. So long as the number
>>>>>>> outstanding at one time is < MAX_ATTR)
>>>>>>> Barry
>>>>>>> On Jun 20, 2020, at 10:54 AM, Junchao Zhang <junchao.zhang at gmail.com>
>>>>>>> wrote:
>>>>>>> I don't understand what your session means. Let's try this patch
>>>>>>> diff --git a/src/sys/mpiuni/mpi.c b/src/sys/mpiuni/mpi.c
>>>>>>> index d559a513..c058265d 100644
>>>>>>> --- a/src/sys/mpiuni/mpi.c
>>>>>>> +++ b/src/sys/mpiuni/mpi.c
>>>>>>> @@ -283,6 +283,7 @@ int MPI_Finalize(void)
>>>>>>> MPI_Comm_free(&comm);
>>>>>>> comm = MPI_COMM_SELF;
>>>>>>> + num_attr = 1; /* reset the counter */
>>>>>>> MPI_was_finalized = 1;
>>>>>>> return MPI_SUCCESS;
>>>>>>> --Junchao Zhang
>>>>>>> On Sat, Jun 20, 2020 at 10:48 AM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>> wrote:
>>>>>>>> Typo: I mean “Assuming initializer is only needed once for entire
>>>>>>>> session”
>>>>>>>> On Saturday, June 20, 2020, Sam Guo <sam.guo at cd-adapco.com> wrote:
>>>>>>>>> Assuming finalizer is only needed once for entire session(?), I
>>>>>>>>> can put initializer into the static block to call it once but where do I
>>>>>>>>> call finalizer?
>>>>>>>>> On Saturday, June 20, 2020, Junchao Zhang <junchao.zhang at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> The counter num_attr should be recycled. But first try to call
>>>>>>>>>> PETSc initialize/Finalize only once to see it fixes the error.
>>>>>>>>>> --Junchao Zhang
>>>>>>>>>> On Sat, Jun 20, 2020 at 12:48 AM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> To clarify, I call PETSc initialize and PETSc finalize
>>>>>>>>>>> everytime I call SLEPc:
>>>>>>>>>>> PetscInitializeNoPointers(argc,args,nullptr,nullptr);
>>>>>>>>>>> SlepcInitialize(&argc,&args,static_cast<char*>(nullptr),help);
>>>>>>>>>>> //calling slepc
>>>>>>>>>>> SlepcFinalize();
>>>>>>>>>>> PetscFinalize();
>>>>>>>>>>> On Fri, Jun 19, 2020 at 10:32 PM Sam Guo <sam.guo at cd-adapco.com>
>>>>>>>>>>> wrote:
>>>>>>>>>>>> Dear PETSc team,
>>>>>>>>>>>> When I called SLEPc multiple time, I eventually got
>>>>>>>>>>>> following error:
>>>>>>>>>>>> MPI operation not supported by PETSc's sequential MPI wrappers
>>>>>>>>>>>> [0]PETSC ERROR: #1 PetscInitialize() line 967 in
>>>>>>>>>>>> [0]PETSC ERROR: #2 SlepcInitialize() line 262 in
>>>>>>>>>>>> [0]PETSC ERROR: #3 SlepcInitializeNoPointers() line 359 in
>>>>>>>>>>>> I debugged: it is because of following in
>>>>>>>>>>>> petsc/src/sys/mpiuni/mpi.c
>>>>>>>>>>>> in function int MPI_Comm_create_keyval(MPI_Copy_function
>>>>>>>>>>>> num_attr is declared static and keeps increasing every
>>>>>>>>>>>> time MPI_Comm_create_keyval is called.
>>>>>>>>>>>> I am using petsc 3.11.3 but found 3.13.2 has the same logic.
>>>>>>>>>>>> Is this a bug or I didn't use it correctly?
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200626/09d5cb80/attachment.html>
