[petsc-users] Parallel writing in HDF5-1.12.0 when some processors have no data to write
Jed Brown
jed at jedbrown.org
Thu Jun 11 22:32:29 CDT 2020
Danyang Su <danyang.su at gmail.com> writes:
> Hi Barry,
> The HDF5 calls fail. I reconfigure PETSc with HDF 1.10.5 version and it works fine on different platforms. So, it is more likely there is a bug in the latest HDF version.
I would double-check that you have not subtly violated a collective requirement in the interface, then report to upstream.
