[petsc-users] Parallel writing in HDF5-1.12.0 when some processors have no data to write
Danyang Su danyang.su at gmail.com
Fri Jun 12 01:15:12 CDT 2020
Hi Jed,
Thanks for your double check.
The HDF 1.10.6 version also works. But versions from 1.12.x stop working.
Attached is the code section where I have problem.
    !c write the dataset collectively
    !!!! CODE CRASHES HERE IF SOME PROCESSORS HAVE NO DATA TO WRITE!!!!
    call h5dwrite_f(dset_id, H5T_NATIVE_DOUBLE, dataset, hdf5_dsize,   &
                    hdf5_ierr, file_space_id=filespace,                &
                    mem_space_id=memspace, xfer_prp = xlist_id)
Please let me know if there is something wrong in the code that causes the problem.
Danyang
On 2020-06-11, 8:32 PM, "Jed Brown" <jed at jedbrown.org> wrote:
    Danyang Su <danyang.su at gmail.com> writes:
    > Hi Barry,
    > The HDF5 calls fail. I reconfigure PETSc with HDF 1.10.5 version and it works fine on different platforms. So, it is more likely there is a bug in the latest HDF version.
    I would double-check that you have not subtly violated a collective requirement in the interface, then report to upstream.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200611/aa1d374f/attachment.obj>
