[petsc-users] Parallel writing in HDF5-1.12.0 when some processors have no data to write
Danyang Su
danyang.su at gmail.com
Thu Jun 11 21:58:13 CDT 2020
Hi Barry,
The HDF5 calls fail. I reconfigure PETSc with HDF 1.10.5 version and it works fine on different platforms. So, it is more likely there is a bug in the latest HDF version.
Thanks.
All the best,
Danyang
On June 11, 2020 5:58:28 a.m. PDT, Barry Smith <bsmith at petsc.dev> wrote:
>Are you making HDF5 calls that fail or is it PETSc routines calling
>HDF5 that fail?
>Regardless it sounds like the easiest fix is to switch back to the
>previous HDF5 and wait for HDF5 to fix what sounds to be a bug.
> Barry
>> On Jun 11, 2020, at 1:05 AM, Danyang Su <danyang.su at gmail.com> wrote:
>> Hi All,
>> Sorry to send the previous incomplete email accidentally.
>> After updating to HDF5-1.12.0, I got some problem if some processors
>have no data to write or not necessary to write. Since parallel writing
>is collective, I cannot disable those processors from writing. For the
>old version, there seems no such problem. So far, the problem only
>occurs on Linux using GNU compiler. The same code has no problem using
>intel compiler or latest gnu compiler on MacOS.
>> I have already included h5sselect_none in the code for those
>processors without data. But it does not take effect. The problem is
>documented in the following link (How do you write data when one
>process doesn't have or need to write data ?).
>> https://support.hdfgroup.org/HDF5/hdf5-quest.html#par-nodata
><https://support.hdfgroup.org/HDF5/hdf5-quest.html#par-nodata>
>> Similar problem has also been reported on HDF Forum by others.
>> https://forum.hdfgroup.org/t/bug-on-hdf5-1-12-0-fortran-parallel/6864
><https://forum.hdfgroup.org/t/bug-on-hdf5-1-12-0-fortran-parallel/6864>
>> Any suggestion for that?
>> Thanks,
>> Danyang
Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200611/7c1d86c0/attachment.html>
