[petsc-users] Running example problem
    Matthew Knepley
    knepley at gmail.com
    Thu Jun  4 11:02:12 CDT 2020
On Thu, Jun 4, 2020 at 11:56 AM Fazlul Huq <huq2090 at gmail.com> wrote:
> I have HYPRE installed in my machine.
> Ithink, I need to compile PETSc with HYPRE.
> I'm not clear about how to do that?
1) Make sure it is the correct version
2) --with-hypre-dir=<path/to/hypre>
     Matt
> Thank you.
> Sincerely,
> Huq
> On Thu, Jun 4, 2020 at 10:13 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jun 4, 2020 at 10:28 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>> Thank you.
>>> Working now.
>>> I think to run the following command I need to configure PETSc with
>>> HYPRE.
>>> mpiexec -np 1 ./poisson_m -n 100000 -pc_type hypre -pc_hypre_type
>>> boomerang
>>> If I am right, can you please guide me how to configure with HYPRE and
>>> run the above command?
>> --download-hypre
>>   Thanks,
>>      Matt
>>> Thank you.
>>> Sincerely,
>>> Huq
>>> On Thu, Jun 4, 2020 at 8:34 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Thu, Jun 4, 2020 at 9:19 AM Dave May <dave.mayhem23 at gmail.com>
>>>> wrote:
>>>>> On Thu, 4 Jun 2020 at 14:17, Dave May <dave.mayhem23 at gmail.com> wrote:
>>>>>> On Thu, 4 Jun 2020 at 14:15, Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Thu, Jun 4, 2020 at 9:12 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>>>>>>> Somehow, make is not working.
>>>>>>>> Please find the attachment herewith for the terminal readout.
>>>>>>> Since you built with PETSC_ARCH=linux-gnu, you need that in your
>>>>>>> environment.
>>>>>> Or just do
>>>>>> make ex5 PETSC_ARCH=linux-gnu
>>>>> sorry I hit send without checking your png)
>>>>> The command should be
>>>>> make ex5 PETSC_ARCH=arch-linux2-c-debug
>>>> No, your first one was right.
>>>>    Matt
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> Thank you.
>>>>>>>> Sincerely,
>>>>>>>> Huq
>>>>>>>> On Thu, Jun 4, 2020 at 7:57 AM Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Thu, Jun 4, 2020 at 8:53 AM Fazlul Huq <huq2090 at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> Hello,
>>>>>>>>>> I have a very preliminary question!
>>>>>>>>>> I think I have installed PETSc correctly cause I got following on
>>>>>>>>>> the terminal:
>>>>>>>>>> Command:
>>>>>>>>>> make PETSC_DIR=/home/huq2090/petsc-3.10.2 PETSC_ARCH=linux-gnu
>>>>>>>>>> check
>>>>>>>>>> Response:
>>>>>>>>>> Running check examples to verify correct installation
>>>>>>>>>> Using PETSC_DIR=/home/huq2090/petsc-3.10.2 and
>>>>>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI
>>>>>>>>>> process
>>>>>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>>>>>>>>>> processes
>>>>>>>>>> Fortran example src/snes/tutorials/ex5f run successfully with 1
>>>>>>>>>> MPI process
>>>>>>>>>> Completed test examples
>>>>>>>>>> Now, I am trying to run an example from the list of provided
>>>>>>>>>> examples.
>>>>>>>>>> Can you please help me out, how to run an example problem from
>>>>>>>>>> the list of examples?
>>>>>>>>>> I mean, how to make executable and run the executable?
>>>>>>>>> cd $PETSC_DIR
>>>>>>>>> cd src/snes/tutorials
>>>>>>>>> make ex5
>>>>>>>>> ./ex5 -snes_monitor
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> Thank you.
>>>>>>>>>> Sincerely,
>>>>>>>>>> Huq
>>>>>>>>>> Fazlul Huq
>>>>>>>>>> Graduate Research Assistant
>>>>>>>>>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>>>>>>>>>> University of Illinois at Urbana-Champaign (UIUC)
>>>>>>>>>> E-mail: huq2090 at gmail.com
>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>> Fazlul Huq
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Fazlul Huq
>> experiments lead.
>> -- Norbert Wiener
> Fazlul Huq
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200604/968fb652/attachment.html>
