[petsc-users] Running example problem
Fazlul Huq huq2090 at gmail.com
Thu Jun 4 10:55:56 CDT 2020
I have HYPRE installed in my machine.
Ithink, I need to compile PETSc with HYPRE.
I'm not clear about how to do that?
Thank you.
Sincerely,
Huq
On Thu, Jun 4, 2020 at 10:13 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jun 4, 2020 at 10:28 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>> Thank you.
>> Working now.
>> I think to run the following command I need to configure PETSc with HYPRE.
>> mpiexec -np 1 ./poisson_m -n 100000 -pc_type hypre -pc_hypre_type
>> boomerang
>> If I am right, can you please guide me how to configure with HYPRE and
>> run the above command?
> --download-hypre
>   Thanks,
>      Matt
>> Thank you.
>> Sincerely,
>> Huq
>> On Thu, Jun 4, 2020 at 8:34 AM Matthew Knepley <knepley at gmail.com> wrote:
>>> On Thu, Jun 4, 2020 at 9:19 AM Dave May <dave.mayhem23 at gmail.com> wrote:
>>>> On Thu, 4 Jun 2020 at 14:17, Dave May <dave.mayhem23 at gmail.com> wrote:
>>>>> On Thu, 4 Jun 2020 at 14:15, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Thu, Jun 4, 2020 at 9:12 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>>>>>> Somehow, make is not working.
>>>>>>> Please find the attachment herewith for the terminal readout.
>>>>>> Since you built with PETSC_ARCH=linux-gnu, you need that in your
>>>>>> environment.
>>>>> Or just do
>>>>> make ex5 PETSC_ARCH=linux-gnu
>>>> sorry I hit send without checking your png)
>>>> The command should be
>>>> make ex5 PETSC_ARCH=arch-linux2-c-debug
>>> No, your first one was right.
>>>    Matt
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Thank you.
>>>>>>> Sincerely,
>>>>>>> Huq
>>>>>>> On Thu, Jun 4, 2020 at 7:57 AM Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Thu, Jun 4, 2020 at 8:53 AM Fazlul Huq <huq2090 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> Hello,
>>>>>>>>> I have a very preliminary question!
>>>>>>>>> I think I have installed PETSc correctly cause I got following on
>>>>>>>>> the terminal:
>>>>>>>>> Command:
>>>>>>>>> make PETSC_DIR=/home/huq2090/petsc-3.10.2 PETSC_ARCH=linux-gnu
>>>>>>>>> check
>>>>>>>>> Response:
>>>>>>>>> Running check examples to verify correct installation
>>>>>>>>> Using PETSC_DIR=/home/huq2090/petsc-3.10.2 and PETSC_ARCH=linux-gnu
>>>>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI
>>>>>>>>> process
>>>>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>>>>>>>>> processes
>>>>>>>>> Fortran example src/snes/tutorials/ex5f run successfully with 1
>>>>>>>>> MPI process
>>>>>>>>> Completed test examples
>>>>>>>>> Now, I am trying to run an example from the list of provided
>>>>>>>>> examples.
>>>>>>>>> Can you please help me out, how to run an example problem from the
>>>>>>>>> list of examples?
>>>>>>>>> I mean, how to make executable and run the executable?
>>>>>>>> cd $PETSC_DIR
>>>>>>>> cd src/snes/tutorials
>>>>>>>> make ex5
>>>>>>>> ./ex5 -snes_monitor
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> Thank you.
>>>>>>>>> Sincerely,
>>>>>>>>> Huq
>>>>>>>>> Fazlul Huq
>>>>>>>>> Graduate Research Assistant
>>>>>>>>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>>>>>>>>> University of Illinois at Urbana-Champaign (UIUC)
>>>>>>>>> E-mail: huq2090 at gmail.com
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>> Fazlul Huq
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> Fazlul Huq
> experiments lead.
> -- Norbert Wiener
Fazlul Huq
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200604/9bf57410/attachment-0001.html>
