[petsc-users] Running example problem
    Matthew Knepley
    knepley at gmail.com
    Thu Jun  4 10:13:02 CDT 2020
On Thu, Jun 4, 2020 at 10:28 AM Fazlul Huq <huq2090 at gmail.com> wrote:
> Thank you.
> Working now.
> I think to run the following command I need to configure PETSc with HYPRE.
> mpiexec -np 1 ./poisson_m -n 100000 -pc_type hypre -pc_hypre_type boomerang
> If I am right, can you please guide me how to configure with HYPRE and run
> the above command?
--download-hypre
     Matt
> Thank you.
> Sincerely,
> Huq
> On Thu, Jun 4, 2020 at 8:34 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jun 4, 2020 at 9:19 AM Dave May <dave.mayhem23 at gmail.com> wrote:
>>> On Thu, 4 Jun 2020 at 14:17, Dave May <dave.mayhem23 at gmail.com> wrote:
>>>> On Thu, 4 Jun 2020 at 14:15, Matthew Knepley <knepley at gmail.com> wrote:
>>>>> On Thu, Jun 4, 2020 at 9:12 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>>>>> Somehow, make is not working.
>>>>>> Please find the attachment herewith for the terminal readout.
>>>>> Since you built with PETSC_ARCH=linux-gnu, you need that in your
>>>>> environment.
>>>> Or just do
>>>> make ex5 PETSC_ARCH=linux-gnu
>>> sorry I hit send without checking your png)
>>> The command should be
>>> make ex5 PETSC_ARCH=arch-linux2-c-debug
>> No, your first one was right.
>>    Matt
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Thank you.
>>>>>> Sincerely,
>>>>>> Huq
>>>>>> On Thu, Jun 4, 2020 at 7:57 AM Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Thu, Jun 4, 2020 at 8:53 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>>>>>>> Hello,
>>>>>>>> I have a very preliminary question!
>>>>>>>> I think I have installed PETSc correctly cause I got following on
>>>>>>>> the terminal:
>>>>>>>> Command:
>>>>>>>> make PETSC_DIR=/home/huq2090/petsc-3.10.2 PETSC_ARCH=linux-gnu check
>>>>>>>> Response:
>>>>>>>> Running check examples to verify correct installation
>>>>>>>> Using PETSC_DIR=/home/huq2090/petsc-3.10.2 and PETSC_ARCH=linux-gnu
>>>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI
>>>>>>>> process
>>>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>>>>>>>> processes
>>>>>>>> Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI
>>>>>>>> process
>>>>>>>> Completed test examples
>>>>>>>> Now, I am trying to run an example from the list of provided
>>>>>>>> examples.
>>>>>>>> Can you please help me out, how to run an example problem from the
>>>>>>>> list of examples?
>>>>>>>> I mean, how to make executable and run the executable?
>>>>>>> cd $PETSC_DIR
>>>>>>> cd src/snes/tutorials
>>>>>>> make ex5
>>>>>>> ./ex5 -snes_monitor
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> Thank you.
>>>>>>>> Sincerely,
>>>>>>>> Huq
>>>>>>>> Fazlul Huq
>>>>>>>> Graduate Research Assistant
>>>>>>>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>>>>>>>> University of Illinois at Urbana-Champaign (UIUC)
>>>>>>>> E-mail: huq2090 at gmail.com
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>> Fazlul Huq
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> Fazlul Huq
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200604/108a74b2/attachment.html>
