[petsc-users] Running example problem
    Fazlul Huq
    huq2090 at gmail.com
    Thu Jun  4 09:28:35 CDT 2020
Thank you.
Working now.
I think to run the following command I need to configure PETSc with HYPRE.
mpiexec -np 1 ./poisson_m -n 100000 -pc_type hypre -pc_hypre_type boomerang
If I am right, can you please guide me how to configure with HYPRE and run
the above command?
Thank you.
Sincerely,
Huq
On Thu, Jun 4, 2020 at 8:34 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jun 4, 2020 at 9:19 AM Dave May <dave.mayhem23 at gmail.com> wrote:
>> On Thu, 4 Jun 2020 at 14:17, Dave May <dave.mayhem23 at gmail.com> wrote:
>>> On Thu, 4 Jun 2020 at 14:15, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Thu, Jun 4, 2020 at 9:12 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>>>> Somehow, make is not working.
>>>>> Please find the attachment herewith for the terminal readout.
>>>> Since you built with PETSC_ARCH=linux-gnu, you need that in your
>>>> environment.
>>> Or just do
>>> make ex5 PETSC_ARCH=linux-gnu
>> sorry I hit send without checking your png)
>> The command should be
>> make ex5 PETSC_ARCH=arch-linux2-c-debug
> No, your first one was right.
>    Matt
>>>>   Thanks,
>>>>      Matt
>>>>> Thank you.
>>>>> Sincerely,
>>>>> Huq
>>>>> On Thu, Jun 4, 2020 at 7:57 AM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Thu, Jun 4, 2020 at 8:53 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>>>>>> Hello,
>>>>>>> I have a very preliminary question!
>>>>>>> I think I have installed PETSc correctly cause I got following on
>>>>>>> the terminal:
>>>>>>> Command:
>>>>>>> make PETSC_DIR=/home/huq2090/petsc-3.10.2 PETSC_ARCH=linux-gnu check
>>>>>>> Response:
>>>>>>> Running check examples to verify correct installation
>>>>>>> Using PETSC_DIR=/home/huq2090/petsc-3.10.2 and PETSC_ARCH=linux-gnu
>>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI
>>>>>>> process
>>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>>>>>>> processes
>>>>>>> Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI
>>>>>>> process
>>>>>>> Completed test examples
>>>>>>> Now, I am trying to run an example from the list of provided
>>>>>>> examples.
>>>>>>> Can you please help me out, how to run an example problem from the
>>>>>>> list of examples?
>>>>>>> I mean, how to make executable and run the executable?
>>>>>> cd $PETSC_DIR
>>>>>> cd src/snes/tutorials
>>>>>> make ex5
>>>>>> ./ex5 -snes_monitor
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Thank you.
>>>>>>> Sincerely,
>>>>>>> Huq
>>>>>>> Fazlul Huq
>>>>>>> Graduate Research Assistant
>>>>>>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>>>>>>> University of Illinois at Urbana-Champaign (UIUC)
>>>>>>> E-mail: huq2090 at gmail.com
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>> Fazlul Huq
>>>> experiments lead.
>>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
Fazlul Huq
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200604/ec27db90/attachment-0001.html>
