[petsc-users] Running example problem
Thu Jun 4 08:34:31 CDT 2020
On Thu, Jun 4, 2020 at 9:19 AM Dave May <dave.mayhem23 at gmail.com> wrote:
> On Thu, 4 Jun 2020 at 14:17, Dave May <dave.mayhem23 at gmail.com> wrote:
>> On Thu, 4 Jun 2020 at 14:15, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Thu, Jun 4, 2020 at 9:12 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>>> Somehow, make is not working.
>>>> Please find the attachment herewith for the terminal readout.
>>> Since you built with PETSC_ARCH=linux-gnu, you need that in your
>>> environment.
>> Or just do
>> make ex5 PETSC_ARCH=linux-gnu
> sorry I hit send without checking your png)
> The command should be
> make ex5 PETSC_ARCH=arch-linux2-c-debug
No, your first one was right.
   Matt
>>>   Thanks,
>>>      Matt
>>>> Thank you.
>>>> Sincerely,
>>>> Huq
>>>> On Thu, Jun 4, 2020 at 7:57 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Thu, Jun 4, 2020 at 8:53 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>>>>> Hello,
>>>>>> I have a very preliminary question!
>>>>>> I think I have installed PETSc correctly cause I got following on the
>>>>>> terminal:
>>>>>> Command:
>>>>>> make PETSC_DIR=/home/huq2090/petsc-3.10.2 PETSC_ARCH=linux-gnu check
>>>>>> Response:
>>>>>> Running check examples to verify correct installation
>>>>>> Using PETSC_DIR=/home/huq2090/petsc-3.10.2 and PETSC_ARCH=linux-gnu
>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI
>>>>>> process
>>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>>>>>> processes
>>>>>> Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI
>>>>>> process
>>>>>> Completed test examples
>>>>>> Now, I am trying to run an example from the list of provided
>>>>>> examples.
>>>>>> Can you please help me out, how to run an example problem from the
>>>>>> list of examples?
>>>>>> I mean, how to make executable and run the executable?
>>>>> cd $PETSC_DIR
>>>>> cd src/snes/tutorials
>>>>> make ex5
>>>>> ./ex5 -snes_monitor
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Thank you.
>>>>>> Sincerely,
>>>>>> Huq
>>>>>> Fazlul Huq
>>>>>> Graduate Research Assistant
>>>>>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>>>>>> University of Illinois at Urbana-Champaign (UIUC)
>>>>>> E-mail: huq2090 at gmail.com
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> Fazlul Huq
>>> experiments lead.
>>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200604/4c3174f9/attachment.html>
