[petsc-users] Running example problem
    Dave May
    dave.mayhem23 at gmail.com
    Thu Jun  4 08:19:17 CDT 2020
On Thu, 4 Jun 2020 at 14:17, Dave May <dave.mayhem23 at gmail.com> wrote:
> On Thu, 4 Jun 2020 at 14:15, Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Jun 4, 2020 at 9:12 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>> Somehow, make is not working.
>>> Please find the attachment herewith for the terminal readout.
>> Since you built with PETSC_ARCH=linux-gnu, you need that in your
>> environment.
> Or just do
> make ex5 PETSC_ARCH=linux-gnu
sorry I hit send without checking your png)
The command should be
make ex5 PETSC_ARCH=arch-linux2-c-debug
>>   Thanks,
>>      Matt
>>> Thank you.
>>> Sincerely,
>>> Huq
>>> On Thu, Jun 4, 2020 at 7:57 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Thu, Jun 4, 2020 at 8:53 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>>>> Hello,
>>>>> I have a very preliminary question!
>>>>> I think I have installed PETSc correctly cause I got following on the
>>>>> terminal:
>>>>> Command:
>>>>> make PETSC_DIR=/home/huq2090/petsc-3.10.2 PETSC_ARCH=linux-gnu check
>>>>> Response:
>>>>> Running check examples to verify correct installation
>>>>> Using PETSC_DIR=/home/huq2090/petsc-3.10.2 and PETSC_ARCH=linux-gnu
>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI
>>>>> process
>>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>>>>> processes
>>>>> Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI
>>>>> process
>>>>> Completed test examples
>>>>> Now, I am trying to run an example from the list of provided examples.
>>>>> Can you please help me out, how to run an example problem from the
>>>>> list of examples?
>>>>> I mean, how to make executable and run the executable?
>>>> cd $PETSC_DIR
>>>> cd src/snes/tutorials
>>>> make ex5
>>>> ./ex5 -snes_monitor
>>>>   Thanks,
>>>>      Matt
>>>>> Thank you.
>>>>> Sincerely,
>>>>> Huq
>>>>> Fazlul Huq
>>>>> Graduate Research Assistant
>>>>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>>>>> University of Illinois at Urbana-Champaign (UIUC)
>>>>> E-mail: huq2090 at gmail.com
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>>> Fazlul Huq
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200604/f9e06de3/attachment-0001.html>
