[petsc-users] Running example problem
Dave May
dave.mayhem23 at gmail.com
Thu Jun 4 08:17:45 CDT 2020
On Thu, 4 Jun 2020 at 14:15, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Jun 4, 2020 at 9:12 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>> Somehow, make is not working.
>> Please find the attachment herewith for the terminal readout.
> Since you built with PETSC_ARCH=linux-gnu, you need that in your
> environment.
Or just do
make ex5 PETSC_ARCH=linux-gnu
> Thanks,
> Matt
>> Thank you.
>> Sincerely,
>> Huq
>> On Thu, Jun 4, 2020 at 7:57 AM Matthew Knepley <knepley at gmail.com> wrote:
>>> On Thu, Jun 4, 2020 at 8:53 AM Fazlul Huq <huq2090 at gmail.com> wrote:
>>>> Hello,
>>>> I have a very preliminary question!
>>>> I think I have installed PETSc correctly cause I got following on the
>>>> terminal:
>>>> Command:
>>>> make PETSC_DIR=/home/huq2090/petsc-3.10.2 PETSC_ARCH=linux-gnu check
>>>> Response:
>>>> Running check examples to verify correct installation
>>>> Using PETSC_DIR=/home/huq2090/petsc-3.10.2 and PETSC_ARCH=linux-gnu
>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI
>>>> process
>>>> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI
>>>> processes
>>>> Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI
>>>> process
>>>> Completed test examples
>>>> Now, I am trying to run an example from the list of provided examples.
>>>> Can you please help me out, how to run an example problem from the list
>>>> of examples?
>>>> I mean, how to make executable and run the executable?
>>> cd $PETSC_DIR
>>> cd src/snes/tutorials
>>> make ex5
>>> ./ex5 -snes_monitor
>>> Thanks,
>>> Matt
>>>> Thank you.
>>>> Sincerely,
>>>> Huq
>>>> Fazlul Huq
>>>> Graduate Research Assistant
>>>> Department of Nuclear, Plasma & Radiological Engineering (NPRE)
>>>> University of Illinois at Urbana-Champaign (UIUC)
>>>> E-mail: huq2090 at gmail.com
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> Fazlul Huq
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200604/80f2ee71/attachment.html>
