[petsc-users] solving saddle point problem in distributed memory
Stefano Zampini stefano.zampini at gmail.com
Tue Jul 28 05:54:50 CDT 2020
If you want advice you should post the error trace PETSc reports.
Anyway, solving Stokes is not so trivial (without direct solvers, you may need mesh dependent information), but we have examples for it
https://gitlab.com/petsc/petsc/-/blob/master/src/ksp/ksp/tutorials/ex42.c <https://gitlab.com/petsc/petsc/-/blob/master/src/ksp/ksp/tutorials/ex42.c>
https://gitlab.com/petsc/petsc/-/blob/master/src/ksp/ksp/tutorials/ex43.c <https://gitlab.com/petsc/petsc/-/blob/master/src/ksp/ksp/tutorials/ex43.c>
https://gitlab.com/petsc/petsc/-/blob/master/src/snes/tutorials/ex69.c <https://gitlab.com/petsc/petsc/-/blob/master/src/snes/tutorials/ex69.c>
If you scroll to the end of those files, you see a bunch of possible options either using PCFIELDSPLIT,  PCBDDC or KSPFETIDP.
> On Jul 28, 2020, at 12:37 PM, Bin Liu <lbllm2018 at hotmail.com> wrote:
> I would like to solve a saddle point problem arising from the stokes equation. I got successful to use the direct solvers in sequential runs. However, I would like to extend it for distributed memory computation. I tried to use superlu_dist, but the program returns errors. Is it possible to solve a saddle point problem in distributed memory using superlu_dist? Could anyone give a simple sample code to set up the parameters of the solver?
> Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200728/296101a3/attachment.html>
