[petsc-users] solving saddle point problem in distributed memory
Bin Liu
lbllm2018 at hotmail.com
Tue Jul 28 19:59:50 CDT 2020
Thanks for your tutorials. Yes. I tried PCFIELDSPLIT. However, it only works for sequential runs. When I run the code in distributed memory, it reports errors. In fact, the essence of my wonder is (a) how to set up superlu_dist in petsc for solving saddle point problem in distributed memory? (b) does the direct solvers in petsc can run in distributed memory for solving saddle point problem?
From: Stefano Zampini [mailto:stefano.zampini at gmail.com]
Sent: Tuesday, 28 July 2020 6:55 PM
To: Bin Liu <lbllm2018 at hotmail.com>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] solving saddle point problem in distributed memory
If you want advice you should post the error trace PETSc reports.
Anyway, solving Stokes is not so trivial (without direct solvers, you may need mesh dependent information), but we have examples for it
https://gitlab.com/petsc/petsc/-/blob/master/src/ksp/ksp/tutorials/ex42.c
https://gitlab.com/petsc/petsc/-/blob/master/src/ksp/ksp/tutorials/ex43.c
https://gitlab.com/petsc/petsc/-/blob/master/src/snes/tutorials/ex69.c
If you scroll to the end of those files, you see a bunch of possible options either using PCFIELDSPLIT, PCBDDC or KSPFETIDP.
On Jul 28, 2020, at 12:37 PM, Bin Liu <lbllm2018 at hotmail.com<mailto:lbllm2018 at hotmail.com>> wrote:
I would like to solve a saddle point problem arising from the stokes equation. I got successful to use the direct solvers in sequential runs. However, I would like to extend it for distributed memory computation. I tried to use superlu_dist, but the program returns errors. Is it possible to solve a saddle point problem in distributed memory using superlu_dist? Could anyone give a simple sample code to set up the parameters of the solver?
Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200729/79530f7e/attachment.html>
