[petsc-users] Installation failure
Rubem Mondaini
rmondaini at csrc.ac.cn
Tue Jul 28 01:38:38 CDT 2020
Thanks a bunch, Satish!
I can configure PETSc now (see configure.log attached), but the compilation breaks down (see make.log). I am wondering if my problem is related to this: https://community.intel.com/t5/Intel-C-Compiler/LIB-VERSION-TYPE-is-undefined-icc-and-icps-errors-under-Debian/td-p/1160017
> -----Original Messages-----
> From: "Satish Balay" <balay at mcs.anl.gov>
> Sent Time: 2020-07-28 13:38:09 (Tuesday)
> To: "Rubem Mondaini" <rmondaini at csrc.ac.cn>
> Cc: "Barry Smith" <bsmith at petsc.dev>, petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] [SPAM] Re: Installation failure
> something went wrong - but petsc configure didn't capture this error.
> You can retry with:
> ./configure PETSC_ARCH=linux-intel --with-cc=mpiicc --with-cxx=0 --with-fc=mpiifort --with-blaslapack-dir=/opt/intel/compilers_and_libraries_2016/linux/mkl --with-scalar-type=complex --with-64-bit-indices
> And perhaps add one more option: LIBS="-Bstatic -lifcore -Bdynamic"
> Note: --with-64-bit-blas-indices is not appropriate here.
> Satish
> On Tue, 28 Jul 2020, Rubem Mondaini wrote:
> > Dear Barry,
> > thank you very much for the reply. I removed the options "--with-mpi-include"
> > and "--with-mpi-lib", but I still get the same error. I attach the
> > configure.log file.
> > I can confirm that I can compile and run other codes with my compilers,
> > however.
> > Many thanks!
> > Rubem
> > On 7/28/20 10:32 AM, Barry Smith wrote:
> > > Hmm, configure is a mess.
> > > Since you explicitly use MPI compilers
> > > --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort
> > > the
> > > --with-mpi-include=/opt/intel/compilers_and_libraries_2016/linux/mpi/intel64/include
> > > --with-mpi-lib=/opt/intel/compilers_and_libraries_2016.3.210/linux/mpi/intel64/lib/libmpicxx.a
> > > are not needed and should not be provided (Satish I thought this would
> > > generate an error? Why doesn't it?)
> > > Please try without those arguments and send the configure.log if it
> > > fails.
> > > The error message isn't completely right.
> > > Cannot run executables created with C.
> > > This is because the call the call to
> > > self.setCompilers.checkCompiler('C') doesn't have enough context to
> > > print a decent error message.
> > > Barry
> > >> On Jul 27, 2020, at 2:06 AM, Rubem Mondaini <rmondaini at csrc.ac.cn> wrote:
> > >> Dears,
> > >> I have tried to install the PETSc library on my machine and I am failing. I
> > >> have managed to install it on another one, which possess similar
> > >> configurations for the compilers, and there things do seem to be very much
> > >> fine.
> > >> I am attaching the corresponding configure.log. Is there something simple
> > >> that I am missing?
> > >> Best,
> > >> <configure.log>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200728/0740ce25/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200728/0740ce25/attachment-0003.bin>
