[petsc-users] SUPERLU_DIST in single precision
Xiaoye S. Li
xsli at lbl.gov
Tue Jul 21 20:36:16 CDT 2020
Yes. We will wait for his reply. -Sherry
On Tue, Jul 21, 2020 at 6:30 PM Barry Smith <bsmith at petsc.dev> wrote:
> Thanks Sherry. But the CPU version runs correctly right so if Felix is
> only interested in CPUs then I could give it to him now?
> Barry
> On Jul 21, 2020, at 7:33 PM, Xiaoye S. Li <xsli at lbl.gov> wrote:
> Barry,
> We have a macro-ized basefile to produced all 4 precisions for
> SuperLU_DIST. In the past, we didn't generate single precision code, since
> there was no request.
> Since now we started working on mixed precision algorithms. I generated
> single precision code a few weeks ago, and fixed some bugs on the way. A
> few days ago, I nailed down a final bug (hopefully) related to single
> precision SGEMM or STRSM BLAS problems on GPU (i.e., single precision
> cuBLAS error). All I know is that CPU code is working on Summit, but it
> has computation errors after I enable GPU. I plan to do some more
> investigation on this before asking Nvidia folks.
> I am busy this week, but should get to it next week. I suggest you wait
> for me to clear this, instead of duplicating the work.
> Sherry
> On Tue, Jul 21, 2020 at 5:22 PM Barry Smith <bsmith at petsc.dev> wrote:
>> Felix,
>> What are your needs, do you want this for CPUs or for GPUs? Do you
>> wish to run all your code in single precision or just the SuperLU_Dist
>> solver while the rest of your code double?
>> If you want to run everything on CPUs using single precision then
>> adding the support is very easy, we can provide that for you any time. The
>> other cases will require more thought.
>> Barry
>> > On Jul 21, 2020, at 8:58 AM, flw at rzg.mpg.de wrote:
>> > Dear PETSc support team,
>> > some time ago you told me that you are planning on releasing a version
>> that supports SUPERLU_DIST in single-precision soon. Can you tell me
>> roughly what time frame you had in mind?
>> > Best regards,
>> > Felix
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200721/278aba21/attachment.html>
