[petsc-users] SUPERLU_DIST in single precision
    flw at rzg.mpg.de
    flw at rzg.mpg.de
    Wed Jul 22 08:04:03 CDT 2020
Hi Barry,
for now I just want to run everything in single on CPUs only with
SUPERLU_DIST. Maybe we will also incorporate GPUs in the future, but
there are no immediate plans yet. So if you could provide the support,
that would be awesome.
Best regards,
Felix
Zitat von Barry Smith <bsmith at petsc.dev>:
> Felix,
>     What are your needs, do you want this for CPUs or for GPUs?  Do
> you wish to run all your code in single precision or just the
> SuperLU_Dist solver while the rest of your code double?
>     If you want to run everything on CPUs using single precision
> then adding the support is very easy, we can provide that for you
> any time. The other cases will require more thought.
>     Barry
>> On Jul 21, 2020, at 8:58 AM, flw at rzg.mpg.de wrote:
>> Dear PETSc support team,
>> some time ago you told me that you are planning on releasing a
>> version that supports SUPERLU_DIST in single-precision soon. Can
>> you tell me roughly what time frame you had in mind?
>> Best regards,
>> Felix
