[petsc-users] SUPERLU_DIST in single precision
Barry Smith bsmith at petsc.dev
Tue Jul 21 20:30:43 CDT 2020
  Thanks Sherry. But the CPU version runs correctly right so if Felix is only interested in CPUs then I could give it to him now?
  Barry
> On Jul 21, 2020, at 7:33 PM, Xiaoye S. Li <xsli at lbl.gov> wrote:
> Barry,
> We have a macro-ized basefile to produced all 4 precisions for SuperLU_DIST. In the past, we didn't generate single precision code, since there was no request.
> Since now we started working on mixed precision algorithms.  I generated single precision code a few weeks ago, and fixed some bugs on the way. A few days ago, I nailed down a final bug (hopefully) related to single precision SGEMM or STRSM BLAS problems on GPU (i.e., single precision cuBLAS error).  All I know is that CPU code is working on Summit, but it has computation errors after I enable GPU.    I plan to do some more investigation on this before asking Nvidia folks.
> I am busy this week, but should get to it next week.  I suggest you wait for me to clear this, instead of duplicating the work.
> Sherry
> On Tue, Jul 21, 2020 at 5:22 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>    Felix,
>     What are your needs, do you want this for CPUs or for GPUs?  Do you wish to run all your code in single precision or just the SuperLU_Dist solver while the rest of your code double?
>     If you want to run everything on CPUs using single precision then adding the support is very easy, we can provide that for you any time. The other cases will require more thought.
>     Barry
> > On Jul 21, 2020, at 8:58 AM, flw at rzg.mpg.de <mailto:flw at rzg.mpg.de> wrote:
> > Dear PETSc support team,
> > some time ago you told me that you are planning on releasing a version that supports SUPERLU_DIST in single-precision soon. Can you tell me roughly what time frame you had in mind?
> > Best regards,
> > Felix
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200721/f893370e/attachment.html>
