[petsc-users] How to add a source term for PETSCFV ?
    Mark Adams
    mfadams at lbl.gov
    Mon Jul 20 08:33:21 CDT 2020
If you search for (-i) "boundary" in ts/ex11.c you will see several
examples of setting BCs with ghost cells in FV.
Don't worry about hyperbolic per se. The PETSc interface is very abstract:
G(x,xdot,t) = F(x,t), or something like that. You can decide which side of
the equation to put each of your terms.
I'm not sure what you mean by derivatives of the context variables, but I
see that FV does not seem to have the auxiliary variable support that FE
has, where we take spatial derivatives of anything that you want.
If you want to have context variables in your cells so that you can take
derivatives in your Riemann solver then you could add dummy variables to
your system like Identity*q = Q. Then q would be in the L/R state variables.
Hope this helps,
On Mon, Jul 20, 2020 at 5:28 AM Thibault Bridel-Bertomeu <
thibault.bridelbertomeu at gmail.com> wrote:
> Dear all,
> I have been studying ex11.c from ts/tutorials to understand how to solve
> an hyperbolic system of equations using PETSCFV. I first worked on the
> Euler equations for inviscid fluids and based on what ex11.c presents, I
> was able to add the right PETSc instructions in an already existing
> in-house code with different gas models  to solve the problems in
> parallel (MPI) and with the AMR capabilities offered by P4EST.
> Now my goal is to move to Navier-Stokes equations. Theoretically the
> system is not completely hyperbolic and can be seen as one with an
> hyperbolic part (identical to the Euler equations) and a parabolic part
> coming from the RHS diffusion terms.
> I have been looking into the manual and also the sources of PETSc around
> the DM, DMPlex, DS and FV classes but I could not find anything that speaks
> to me as "adding a RHS to an hyperbolic system of equations" or "adding a
> source term to an hyperbolic system of equations". What's more, that source
> term depends on the derivatives of the context variables ...
> I wanted to know if anyone maybe had a suggestion regarding this issue ?
> Thank you very much in advance,
> Eng, MSc, PhD
> Research Engineer
> CEA/CESTA
> 33114 LE BARP
> Tel.: (+33)557046924
> Mob.: (+33)611025322
> Mail: thibault.bridelbertomeu at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200720/41083884/attachment-0001.html>
