[petsc-users] How to add a source term for PETSCFV ?
Thibault Bridel-Bertomeu
thibault.bridelbertomeu at gmail.com
Mon Jul 20 04:26:58 CDT 2020
Dear all,
I have been studying ex11.c from ts/tutorials to understand how to solve an
hyperbolic system of equations using PETSCFV. I first worked on the Euler
equations for inviscid fluids and based on what ex11.c presents, I was able
to add the right PETSc instructions in an already existing in-house code
with different gas models to solve the problems in parallel (MPI) and with
the AMR capabilities offered by P4EST.
Now my goal is to move to Navier-Stokes equations. Theoretically the system
is not completely hyperbolic and can be seen as one with an hyperbolic part
(identical to the Euler equations) and a parabolic part coming from the RHS
diffusion terms.
I have been looking into the manual and also the sources of PETSc around
the DM, DMPlex, DS and FV classes but I could not find anything that speaks
to me as "adding a RHS to an hyperbolic system of equations" or "adding a
source term to an hyperbolic system of equations". What's more, that source
term depends on the derivatives of the context variables ...
I wanted to know if anyone maybe had a suggestion regarding this issue ?
Thank you very much in advance,
Eng, MSc, PhD
Research Engineer
CEA/CESTA
33114 LE BARP
Tel.: (+33)557046924
Mob.: (+33)611025322
Mail: thibault.bridelbertomeu at gmail.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200720/0db9be45/attachment-0001.html>
