[petsc-users] Tough to reproduce petsctablefind error
Fande Kong fdkong.jd at gmail.com
Mon Jul 20 00:16:00 CDT 2020
Trace could look like this:
[640]PETSC ERROR: --------------------- Error Message
[640]PETSC ERROR: Argument out of range
[640]PETSC ERROR: key 45226154 is greater than largest key allowed 740521
[640]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for
trouble shooting.
[640]PETSC ERROR: Petsc Release Version 3.13.3, unknown
[640]PETSC ERROR: ../../griffin-opt on a arch-moose named r6i5n18 by wangy2
Sun Jul 19 17:14:28 2020
[640]PETSC ERROR: Configure options --download-hypre=1 --with-debugging=no
--with-shared-libraries=1 --download-fblaslapack=1 --download-metis=1
--download-ptscotch=1 --download-parmetis=1 --download-superlu_dist=1
--download-mumps=1 --download-scalapack=1 --download-slepc=1 --with-mpi=1
--with-cxx-dialect=C++11 --with-fortran-bindings=0 --with-sowing=0
--with-64-bit-indices --download-mumps=0
[640]PETSC ERROR: #1 PetscTableFind() line 132 in
/home/wangy2/trunk/sawtooth/griffin/moose/petsc/include/petscctable.h
[640]PETSC ERROR: #2 MatSetUpMultiply_MPIAIJ() line 33 in
/home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/impls/aij/mpi/mmaij.c
[640]PETSC ERROR: #3 MatAssemblyEnd_MPIAIJ() line 876 in
/home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/impls/aij/mpi/mpiaij.c
[640]PETSC ERROR: #4 MatAssemblyEnd() line 5347 in
/home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/interface/matrix.c
[640]PETSC ERROR: #5 MatPtAPNumeric_MPIAIJ_MPIXAIJ_allatonce() line 901 in
/home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/impls/aij/mpi/mpiptap.c
[640]PETSC ERROR: #6 MatPtAPNumeric_MPIAIJ_MPIMAIJ_allatonce() line 3180 in
/home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/impls/maij/maij.c
[640]PETSC ERROR: #7 MatProductNumeric_PtAP() line 704 in
/home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/interface/matproduct.c
[640]PETSC ERROR: #8 MatProductNumeric() line 759 in
[640]PETSC ERROR: #9 MatPtAP() line 9199 in
[640]PETSC ERROR: #10 MatGalerkin() line 10236 in
[640]PETSC ERROR: #11 PCSetUp_MG() line 745 in
/home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/pc/impls/mg/mg.c
[640]PETSC ERROR: #12 PCSetUp_HMG() line 220 in
/home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/pc/impls/hmg/hmg.c
[640]PETSC ERROR: #13 PCSetUp() line 898 in
/home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/pc/interface/precon.c
[640]PETSC ERROR: #14 KSPSetUp() line 376 in
/home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/ksp/interface/itfunc.c
[640]PETSC ERROR: #15 KSPSolve_Private() line 633 in
[640]PETSC ERROR: #16 KSPSolve() line 853 in
[640]PETSC ERROR: #17 SNESSolve_NEWTONLS() line 225 in
/home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/snes/impls/ls/ls.c
[640]PETSC ERROR: #18 SNESSolve() line 4519 in
/home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/snes/interface/snes.c
On Sun, Jul 19, 2020 at 11:13 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> I am not entirely sure what is happening, but we encountered similar
> issues recently.  It was not reproducible. It might occur at different
> stages, and errors could be weird other than "ctable stuff." Our code was
> Valgrind clean since every PR in moose needs to go through rigorous
> Valgrind checks before it reaches the devel branch.  The errors happened
> when we used mvapich.
> We changed to use HPE-MPT (a vendor stalled MPI), then everything was
> smooth.  May you try a different MPI? It is better to try a system carried
> one.
> We did not get the bottom of this problem yet, but we at least know this
> is kind of MPI-related.
> Thanks,
> Fande,
> On Sun, Jul 19, 2020 at 3:28 PM Chris Hewson <chris at resfrac.com> wrote:
>> Hi,
>> I am having a bug that is occurring in PETSC with the return string:
>> [7]PETSC ERROR: PetscTableFind() line 132 in
>> /home/chewson/petsc-3.13.2/include/petscctable.h key 7556 is greater than
>> largest key allowed 5693
>> This is using petsc-3.13.2, compiled and running using mpich with -O3 and
>> debugging turned off tuned to the haswell architecture and occurring either
>> before or during a KSPBCGS solve/setup or during a MUMPS factorization
>> solve (I haven't been able to replicate this issue with the same set of
>> instructions etc.).
>> This is a terrible way to ask a question, I know, and not very helpful
>> from your side, but this is what I have from a user's run and can't
>> reproduce on my end (either with the optimization compilation or with
>> debugging turned on). This happens when the code has run for quite some
>> time and is happening somewhat rarely.
>> More than likely I am using a static variable (code is written in c++)
>> that I'm not updating when the matrix size is changing or something silly
>> like that, but any help or guidance on this would be appreciated.
>> *Chris Hewson*
>> Senior Reservoir Simulation Engineer
>> ResFrac
>> +1.587.575.9792
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200719/e9072376/attachment.html>
