[petsc-users] Tough to reproduce petsctablefind error
Barry Smith
bsmith at petsc.dev
Mon Jul 20 07:03:54 CDT 2020
Is there a comprehensive MPI test suite (perhaps from MPICH)? Is there any way to run this full test suite under the problematic MPI and see if it detects any problems?
Is so, could someone add it to the FAQ in the debugging section?
Thanks
Barry
> On Jul 20, 2020, at 12:16 AM, Fande Kong <fdkong.jd at gmail.com> wrote:
> Trace could look like this:
> [640]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [640]PETSC ERROR: Argument out of range
> [640]PETSC ERROR: key 45226154 is greater than largest key allowed 740521
> [640]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble shooting.
> [640]PETSC ERROR: Petsc Release Version 3.13.3, unknown
> [640]PETSC ERROR: ../../griffin-opt on a arch-moose named r6i5n18 by wangy2 Sun Jul 19 17:14:28 2020
> [640]PETSC ERROR: Configure options --download-hypre=1 --with-debugging=no --with-shared-libraries=1 --download-fblaslapack=1 --download-metis=1 --download-ptscotch=1 --download-parmetis=1 --download-superlu_dist=1 --download-mumps=1 --download-scalapack=1 --download-slepc=1 --with-mpi=1 --with-cxx-dialect=C++11 --with-fortran-bindings=0 --with-sowing=0 --with-64-bit-indices --download-mumps=0
> [640]PETSC ERROR: #1 PetscTableFind() line 132 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/include/petscctable.h
> [640]PETSC ERROR: #2 MatSetUpMultiply_MPIAIJ() line 33 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/impls/aij/mpi/mmaij.c
> [640]PETSC ERROR: #3 MatAssemblyEnd_MPIAIJ() line 876 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/impls/aij/mpi/mpiaij.c
> [640]PETSC ERROR: #4 MatAssemblyEnd() line 5347 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/interface/matrix.c
> [640]PETSC ERROR: #5 MatPtAPNumeric_MPIAIJ_MPIXAIJ_allatonce() line 901 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/impls/aij/mpi/mpiptap.c
> [640]PETSC ERROR: #6 MatPtAPNumeric_MPIAIJ_MPIMAIJ_allatonce() line 3180 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/impls/maij/maij.c
> [640]PETSC ERROR: #7 MatProductNumeric_PtAP() line 704 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/interface/matproduct.c
> [640]PETSC ERROR: #8 MatProductNumeric() line 759 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/interface/matproduct.c
> [640]PETSC ERROR: #9 MatPtAP() line 9199 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/interface/matrix.c
> [640]PETSC ERROR: #10 MatGalerkin() line 10236 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/mat/interface/matrix.c
> [640]PETSC ERROR: #11 PCSetUp_MG() line 745 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/pc/impls/mg/mg.c
> [640]PETSC ERROR: #12 PCSetUp_HMG() line 220 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/pc/impls/hmg/hmg.c
> [640]PETSC ERROR: #13 PCSetUp() line 898 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/pc/interface/precon.c
> [640]PETSC ERROR: #14 KSPSetUp() line 376 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/ksp/interface/itfunc.c
> [640]PETSC ERROR: #15 KSPSolve_Private() line 633 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/ksp/interface/itfunc.c
> [640]PETSC ERROR: #16 KSPSolve() line 853 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/ksp/ksp/interface/itfunc.c
> [640]PETSC ERROR: #17 SNESSolve_NEWTONLS() line 225 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/snes/impls/ls/ls.c
> [640]PETSC ERROR: #18 SNESSolve() line 4519 in /home/wangy2/trunk/sawtooth/griffin/moose/petsc/src/snes/interface/snes.c
> On Sun, Jul 19, 2020 at 11:13 PM Fande Kong <fdkong.jd at gmail.com <mailto:fdkong.jd at gmail.com>> wrote:
> I am not entirely sure what is happening, but we encountered similar issues recently. It was not reproducible. It might occur at different stages, and errors could be weird other than "ctable stuff." Our code was Valgrind clean since every PR in moose needs to go through rigorous Valgrind checks before it reaches the devel branch. The errors happened when we used mvapich.
> We changed to use HPE-MPT (a vendor stalled MPI), then everything was smooth. May you try a different MPI? It is better to try a system carried one.
> We did not get the bottom of this problem yet, but we at least know this is kind of MPI-related.
> Thanks,
> Fande,
> On Sun, Jul 19, 2020 at 3:28 PM Chris Hewson <chris at resfrac.com <mailto:chris at resfrac.com>> wrote:
> Hi,
> I am having a bug that is occurring in PETSC with the return string:
> [7]PETSC ERROR: PetscTableFind() line 132 in /home/chewson/petsc-3.13.2/include/petscctable.h key 7556 is greater than largest key allowed 5693
> This is using petsc-3.13.2, compiled and running using mpich with -O3 and debugging turned off tuned to the haswell architecture and occurring either before or during a KSPBCGS solve/setup or during a MUMPS factorization solve (I haven't been able to replicate this issue with the same set of instructions etc.).
> This is a terrible way to ask a question, I know, and not very helpful from your side, but this is what I have from a user's run and can't reproduce on my end (either with the optimization compilation or with debugging turned on). This happens when the code has run for quite some time and is happening somewhat rarely.
> More than likely I am using a static variable (code is written in c++) that I'm not updating when the matrix size is changing or something silly like that, but any help or guidance on this would be appreciated.
> Chris Hewson
> Senior Reservoir Simulation Engineer
> ResFrac
> +1.587.575.9792
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200720/d1670634/attachment.html>
