[petsc-users] Fwd: Running moose/scripts/update_and_rebuild_petsc.sh on HPC
Satish Balay
balay at mcs.anl.gov
Thu Jan 30 16:09:21 CST 2020
Ah - missed that part. I've updated the branch/MR.
Thanks!
Satish
On Thu, 30 Jan 2020, Tomas Mondragon wrote:
> Just to be extra safe, that fix should also be applied to the
> 'with-executables-search-path' section as well, but your fix did help me
> get past the checks for lgrind and c2html.
> On Thu, Jan 30, 2020, 3:47 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > I pushed a fix to branch balay/fix-check-files-in-path - please give it a
> > try.
> > https://gitlab.com/petsc/petsc/-/merge_requests/2490
> > Satish
> > On Thu, 30 Jan 2020, Satish Balay via petsc-users wrote:
> > > The issue is:
> > > [Errno 13] Permission denied: '/pbs/SLB'
> > > Try removing this from PATH - and rerun configure.
> > > This part of configure code should be fixed.. [or protected with 'try']
> > > Satish
> > > On Thu, 30 Jan 2020, Fande Kong wrote:
> > > > Hi All,
> > > > It looks like a bug for me.
> > > > PETSc was still trying to detect lgrind even we set "--with-lgrind=0".
> > The
> > > > configuration log is attached. Any way to disable lgrind detection.
> > > > Thanks,
> > > > Fande
> > > > ---------- Forwarded message ---------
> > > > From: Tomas Mondragon <tom.alex.mondragon at gmail.com>
> > > > Date: Thu, Jan 30, 2020 at 9:54 AM
> > > > Subject: Re: Running moose/scripts/update_and_rebuild_petsc.sh on HPC
> > > > To: moose-users <moose-users at googlegroups.com>
> > > > Configuration log is attached
