[petsc-users] Fwd: Running moose/scripts/update_and_rebuild_petsc.sh on HPC
Satish Balay
balay at mcs.anl.gov
Thu Jan 30 16:26:26 CST 2020
Pushed one more change - move duplicate/similar code into a function.
Satish
On Thu, 30 Jan 2020, Satish Balay via petsc-users wrote:
> Ah - missed that part. I've updated the branch/MR.
> Thanks!
> Satish
> On Thu, 30 Jan 2020, Tomas Mondragon wrote:
> > Just to be extra safe, that fix should also be applied to the
> > 'with-executables-search-path' section as well, but your fix did help me
> > get past the checks for lgrind and c2html.
> > On Thu, Jan 30, 2020, 3:47 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > I pushed a fix to branch balay/fix-check-files-in-path - please give it a
> > > try.
> > > https://gitlab.com/petsc/petsc/-/merge_requests/2490
> > > Satish
> > > > The issue is:
> > > > [Errno 13] Permission denied: '/pbs/SLB'
> > > > Try removing this from PATH - and rerun configure.
> > > > This part of configure code should be fixed.. [or protected with 'try']
> > > > Satish
> > > > On Thu, 30 Jan 2020, Fande Kong wrote:
> > > > > Hi All,
> > > > > It looks like a bug for me.
> > > > > PETSc was still trying to detect lgrind even we set "--with-lgrind=0".
> > > The
> > > > > configuration log is attached. Any way to disable lgrind detection.
> > > > > Thanks,
> > > > > Fande
> > > > > ---------- Forwarded message ---------
> > > > > From: Tomas Mondragon <tom.alex.mondragon at gmail.com>
> > > > > Date: Thu, Jan 30, 2020 at 9:54 AM
> > > > > Subject: Re: Running moose/scripts/update_and_rebuild_petsc.sh on HPC
> > > > > To: moose-users <moose-users at googlegroups.com>
> > > > > Configuration log is attached
