[petsc-users] Fwd: Running moose/scripts/update_and_rebuild_petsc.sh on HPC
Tomas Mondragon
tom.alex.mondragon at gmail.com
Thu Jan 30 16:03:00 CST 2020
Just to be extra safe, that fix should also be applied to the
'with-executables-search-path' section as well, but your fix did help me
get past the checks for lgrind and c2html.
On Thu, Jan 30, 2020, 3:47 PM Satish Balay <balay at mcs.anl.gov> wrote:
> I pushed a fix to branch balay/fix-check-files-in-path - please give it a
> try.
> https://gitlab.com/petsc/petsc/-/merge_requests/2490
> Satish
> On Thu, 30 Jan 2020, Satish Balay via petsc-users wrote:
> > The issue is:
> > [Errno 13] Permission denied: '/pbs/SLB'
> > Try removing this from PATH - and rerun configure.
> > This part of configure code should be fixed.. [or protected with 'try']
> > Satish
> > On Thu, 30 Jan 2020, Fande Kong wrote:
> > > Hi All,
> > > It looks like a bug for me.
> > > PETSc was still trying to detect lgrind even we set "--with-lgrind=0".
> The
> > > configuration log is attached. Any way to disable lgrind detection.
> > > Thanks,
> > > Fande
> > > ---------- Forwarded message ---------
> > > From: Tomas Mondragon <tom.alex.mondragon at gmail.com>
> > > Date: Thu, Jan 30, 2020 at 9:54 AM
> > > Subject: Re: Running moose/scripts/update_and_rebuild_petsc.sh on HPC
> > > To: moose-users <moose-users at googlegroups.com>
> > > Configuration log is attached
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200130/5447a06f/attachment.html>
