[petsc-users] Fwd: Running moose/scripts/update_and_rebuild_petsc.sh on HPC
Satish Balay
balay at mcs.anl.gov
Thu Jan 30 15:47:08 CST 2020
I pushed a fix to branch balay/fix-check-files-in-path - please give it a try.
https://gitlab.com/petsc/petsc/-/merge_requests/2490
Satish
On Thu, 30 Jan 2020, Satish Balay via petsc-users wrote:
> The issue is:
> [Errno 13] Permission denied: '/pbs/SLB'
> Try removing this from PATH - and rerun configure.
> This part of configure code should be fixed.. [or protected with 'try']
> Satish
> On Thu, 30 Jan 2020, Fande Kong wrote:
> > Hi All,
> > It looks like a bug for me.
> > PETSc was still trying to detect lgrind even we set "--with-lgrind=0". The
> > configuration log is attached. Any way to disable lgrind detection.
> > Thanks,
> > Fande
> > ---------- Forwarded message ---------
> > From: Tomas Mondragon <tom.alex.mondragon at gmail.com>
> > Date: Thu, Jan 30, 2020 at 9:54 AM
> > Subject: Re: Running moose/scripts/update_and_rebuild_petsc.sh on HPC
> > To: moose-users <moose-users at googlegroups.com>
> > Configuration log is attached
